Meshtastic
Project Meshtastic | |
Experiments with Meshtastic | |
Contact | bertrik |
Last Update | 2025-03-12 |
1. Intro
The plan is to use Meshtastic to transfer citizen science measurement data.
Stuff to figure out:
- network coverage: meshnet.nl map
- do nodes forward packets that do not belong to their "own" network? -> appears to be so!
My node: https://db.meshnet.nl/da639b54.html
Done:
- I know the basics of meshtastic
- Understand how the encryption works, how keys are constructed, how nonce/salt is constructed
- Can pick up messages sent through the network and shared via MQTT back into a local application and decrypt them
TODO
- create a particulate matter sensor that sends meshtastic
- figure out the LoRa settings for a LoRa transceiver
- actually build it and test it out
- write a backend/plugin for my sensor-data-bridge
2. Design
Overall design:
- citizen science nodes send data in meshtastic-compatible format, so packets can be routed accross the meshtastic network
- data is sent from the node typically every 5 minutes
- data is broadcasted inside the network, until it reaches a node with a MQTT backend connection, typically within a maximum of 3 hops.
- data arriving at the MQTT server is picked up by a backend application, which can then process it further
- we use a more-or-less citizen-science-data specific channel, so we don't interfere with other meshtastic traffic
Protocol design:
- Use either the default channel (longfast + 01-key) or a dedicated channel (longfast? + custom key)
- Use standard network concepts from meshtastic to comply with meshtastic expectations for smooth operation
- Use meshtastic google protobuf for the network part, with a custom port > 256, e.g. 300
- Use custom encoding within the payload, basically the same as now
- A 16-bit checksum at the end of the payload allows us to verify that it really is a citizen science data packet after decryption
- Each packet already has a semi-unique packet id, so we can identify duplicates at the backend
Backend:
- The backend application listens on a topic on the de-facto central MQTT server for the netherlands, used by most meshtastic nodes, which is mqtt.meshnet.nl
- Decoding works as follows:
- Decrypt with the pre-shared-key (this always work but might result in garbage)
- Attempt to decode according to the the protobuf portnum+payload (meshtastic 'Data')
- Check the port number
- Check and remove the 16-bit checksum in the payload
- If all of the steps above check out, consider it to be a valid packet
- Check in a local cache if this is a duplicate packet and if so, ignore it
- process citizen science data payload: there is no such thing as TTN attributes, so any data required for further forwarding need to be kept locally (e.g. login credentials for opensense / sensor.community)
2.1. Packet structure
On the radio level:
[ lora preamble | ... | <payload> ] <to be documented>
Within the radio payload:
[ meshtastic 16-byte header | protobuf containing portnum + payload ] |<-- encrypted part -->]
Within the protobuf payload, data encoded according to custom encoding (e.g. packed binary)
[citizen science data | 16-bit CRC]
3. Protocol
Quick links:
- radio parameters, for LongFast
- Frequency: 869.525 MHz
- LongFast = SF9BW250, CR 4/5, 8 symbols preamble, explicit header, CRC on (?)
- sync word = 0x2B ("to be"), used to be 0x12, source code mentions it to be some hash containing channel name
- data structure:
- unencrypted header https://meshtastic.org/docs/overview/mesh-algo/#layer-1-unreliable-zero-hop-messaging
- Service Envelope, wraps a MeshPacket: https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.ServiceEnvelope
- MeshPacket https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.MeshPacket loosely based on the message as sent over-the-air
- Port numbers: https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.PortNum
- Meshtastic encryption https://meshtastic.org/docs/overview/encryption/ This is very incomplete! Details need to be reverse-engineered from the code!
4. Hardware
5. MQTT
In the netherlands, data is typically sent to the 'boreft' MQTT server, for example
Examples of typical data:
5.1. Example data
Examples of data as decoded from MQTT using the meshtastic python service wrapper:
packet { from: 2732702784 to: 4294967295 decoded { portnum: POSITION_APP payload: "\r\224\234\024\037\025\303\266\233\002\030\n\270\001 " } id: 663882246 rx_time: 1741511999 rx_snr: -18 hop_limit: 2 rx_rssi: -128 hop_start: 3 } channel_id: "LongFast" gateway_id: "!da544e50"
Packet with encrypted data:
packet { from: 1128181476 to: 4294967295 channel: 8 encrypted: "\007\355{o\340e\352\221\204\3112\365h\304[0\321&\351^{]\264\334\373\320\313>\213\2635\023\345'" id: 4272151039 rx_time: 1741512321 rx_snr: 5.75 hop_limit: 4 rx_rssi: -83 hop_start: 5 } channel_id: "LongFast" gateway_id: "!da5c87d4"
