FMCWRadar
Revision as of 20:31, 7 January 2025 by Bertrik Sikken (talk | contribs) (What)
Project FMCWRadar
Experimenting with inexpensive FMCW radar modules
Last Update 2025-01-07
What
  • gaining experience with the hardware
  • gaining experience on what kind of compensation/calibration is needed
  • apply it in a fun project, e.g. pedestrian speed indicator, or detect bats with it
Perhaps start a collection of inexpensive "software-defined" radar projects?
The current generation of inexpensive radar modules (around E40,-) has these typical features:
  • operates on 24 GHz
  • has quadrature outputs (I and Q) so it can not just detect movement (through Doppler) but also distinguish direction
  • has a modulation input that allows a subtle change of the radar operating frequency
  • often combined with a cortex M0 or M3/M4 microcontroller,
  • pre-configured with firmware to do detection of object speed and direction
External links:
Theory
  • I and Q outputs as described above
  • Modulation input, that allows you to quickly sweep the radar frequency
IVS-362
  • tuning voltage range about 0.7 - 2.5 V = 1.8V
  • modulation sensitivity = 720 MHz/V
NJR
https://www.njr.com/micro/download/datasheet/sensor/NJR4234BV_Datasheet_Rev00-02e.pdf
  • mentions a sweep time of 1024 us, supporting the typical 1 ms sweep time assumed in the calculation below
  • mentions a bandwidth of 177 MHz, comparable with the assumption as used in the calculation below
calculation
  • radar works at 24 GHz, therefore wavelength = 12.5 mm
  • suppose the range of a full FM sweep is 150 MHz
  • object distance d is 1 meter, so time-of-flight = 2 * d / c = 6.67 ns
  • to get a 1 kHz difference frequency at this range, we need a chirp rate of delta_f / delta_t = 1 kHz / 6.67 ns = 150 GHz/s
  • the FM sweep therefore has to be done in 150 MHz / 150 GHz/s = 1 ms, or 1000 sweeps/s
  • suppose the FM sweep consists of 100 individual steps, we need 100,000 steps/s
Challenges
  • Hardware:
    • do the available radar modules actually use the FM modulation input of the radar? -> I will assume that unless it's specifically advertised, this is NOT the case (even though it uses a frontend that could)
    • how is the FM modulation input wired to the CPU? The STM32 processors typically used don't have a DAC output! -> is the ramp perhaps generated with help of an opamp circuit (e.g. current source charging a capacitor)
    • some STM32 MCUs *do* have a DAC, see this application note
  • Software:
    • can we find source code of existing firmwares? -> probably NO at this point
    • can we reprogram the microcontroller -> SWD-signals are generally brought out to a header -> might be flash locked, might be possible to physically replace with an unlocked STM32
      • This application note describes the levels: in short 0 = fully unlocked, 1 = flash locked but JTAG/SWD/etc still works, unlock erases flash, 2 = fully locked, JTAG/SWD/etc disabled
  • How to cope with real-world inaccuracies, like IQ inbalance -> I guess now that a linear correction matrix can fix most of it, but how to determine the coefficients, preferably automatically
    • I-Q outputs are not exactly 90 degrees apart
    • I-Q outputs have an amplitude inbalance
    • I-Q outputs have a bias
    • dynamic range: this needs to be high, since the radar equation has a 4th-power dependency on distance -> maybe not so critical, range detection relies on measuring a frequency, not an amplitude
  • Get some rough idea of
    • inaccuracies a described above
    • Frequency change per m/s
    • Typical modulation index: MHz / V on the modulation input, and the corresponding sweep rate > 150 MHz / ms doesn't seem unreasonable
  • Choose signal processing properties
    • choose an appropriate sample rate
    • can we calculate an FFT fast enough, fixed point or floating point
    • what properties should the FFT have, obviously complex->complex, window function?
    • can we stack multiple FFTs for increased sensitivity? -> yes probably, stack them in IQ (not power)
Available FMCW radar modules
Ai Thinker
RD-03
aithinker rd-03
aithinker rd-03
Links:
Parts:
  • radar chip: S3KM1110
  • controller chip: F003F17 / 2L6T13B, PY32F003F17U
This thing outputs ASCII strings over a serial port at 115200, for example:
ON
Range 46
That appears to be all.
RD-03E
Links:
Hardware markings:
  • E230K8 / BSK4KM / JJ 2331 / GD ARM
  • should contain an S3KM111L, this chip has an internal FMCW waveform generator (up to 8 kHz sweep rate)
Various
DF robot:
Acconeer radars:
From Yanwu Tech:
  • FMK24-A series, a range of FMCW modules which appear identical in hardware at least, a.k.a. as "FM24-NP100".
  • FM24-NP100 on Aliexpress.
AliExpress 24 GHz radar with FMCW, with CPU:
-> claimed to support FMCW, outputs for divided signal, temperature, for about E15,- . See also https://img.alicdn.com/imgextra/i1/2207378167020/O1CN01dUjv6p21jD06t4F3w_!!2207378167020.jpg . Appears to suggest that the IMD2411A2 uses 3.0V and the IFL2411A2 uses 3.3V. Both have "ADC DAC" interface.
  • RD2411A has a review claiming it actually works for distance measurement up to 5m: "The seller sended a datasheet of the unit, so I was able to read out the unit. measurements till 5 meters are no problem, I did not test greater distances. The measurement speed is very low, and needs 600ms. The current stays at 150mA, so it is not very usable in battety equipment "
Hi-link
Hi-link radars, available on AliExpress, typically separate analog frontend + CPU for processing, serial output:
Analog front-end
  • this page claims it has an SPI interface, but I doubt that
  • 250 MHz bandwidth
  • 25 dB receive gain
  • run at 3.3V, 58 mA current typical
  • 16 pins
Experimentation
HLK-LD2410
Expimental software to communicate with this module, running on ESP8266: https://github.com/bertrik/hlk-ld2410
Information: https://drive.google.com/drive/folders/1p4dhbEJA3YubyIjIIC7wwVsSo8x29Fq-
Hardware:
  • radar-side: S3KM111L / 1540101D1 / 2209H
  • electronics side: BPCK234-23A2
Protocol: https://github.com/ESPresense/ESPresense/files/9312938/HLK-LD2410.Serial.Communication.Protocol.V1.02.pdf
Apparently, the device has two kinds of responses:
  • ACK, in response to a command, starting with bytes FD FC FB FA
  • measurement report, sent unsollicited, starting with bytes F4 F3 F2 F1
  • add function to configure the module for a more reasonable bit rate (e.g. 9600 bps) instead of 256000 bps
HLK-LD1115H-24G
Information at manufacturer: https://hlktech.net/index.php?id=973&cateid=749
Can't find a proper datasheet, but found some info here: https://community.home-assistant.io/t/how-to-work-with-hlk-ld1115h-and-wemos-d1-mini-for-human-presence-detection/434427
It mainly outputs two messages:
  • occ, for occupancy (or small movement)
  • mov, for movement (or large movement)
YH-K24-G01
I have an YH-K24-G01.
It works as a Doppler sensor.
HLK-LD303-24G
HLK-LD303-24G
More info: https://www.hlktech.com/en/Goods-94.html
Components on this board:
  • An "CKCA32" STM32-compatible in LQFP-48 pinout
  • MV324, quad opamp
  • 8 MHz crystal
  • HT50 (5V regulator?) plus two 3.3V regulators (probably)
  • radar is an Infineon BGT24LTR11N16 (package says "LTR11" "2020")
Oddly enough, I cannot find a signal going from the I and Q signals to the opamp, so perhaps the opamp has nothing to do with the I and Q signals at all! Possibly only used for generation an FMCW ramp?
There is a blue LED connected to pin PB9.
STM32 pinout
Pin Name Function
12 PA2/ADC12_IN2 radar-I
13 PA3/ADC12_IN3 radar-Q
26 PB13/SPI2_SCK ???
30 PA9/USART1_TX serial TX?
31 PA10/USART1_RX serial RX?
46 PB9 blue LED
Pinout
Arduino Module Remark
D2 red wire Arduino TX
D3 yellow wire Arduino RX
GND black wire ground
5V white wire power
NOTE: the pinout as shown on the PCB *does not* match the header!
Parameters
Internal parameters of the HLK-LD303, partially inferred from datasheets (translated from Chinese):
Code Parameter Parameter value Remarks
B1 Operating mode 0 = sensitive, 1 = stable -
B3 Fitting coefficient (0.001) ? -
B4 Offset correction (cm) ? -
D1 Delay time (ms) 200-3000, default 1000 The time the output (blue LED) stays active after detection
D2 Close treatment 0 = keep last measured distance, 1 = clear distance result -
D3 Measurement - Start measurement in mode 6, using the 'query' command packet
D4 Baud rate (unit 100 bps) - Set baud rate, activated on next power-up
D5 Trigger threshold (unit: 'k') 30-3000, default 100 -
D9 Output target 0 = nearest, 1 = maximum goal ?
DA Signal interval (unit: 40ms) 5-20, default 10
DE Reset 0
E0 Minimum detection distance (cm) 0-200, default 30 -
E1 Sensitivity 60-2000, default 300 Smaller number means more sensitive, it acts like an activity threshold for detection
E5 Maximum detection distance (cm) 50-350, default 350 -
E6 Report interval (unit: 40ms) 0-20 -
E7 Extreme values stats 0-100, default 0 -
E8 Extreme filter times default 0 -
E9 Number of swipes 0-100, default 10 -
F6 Protocol type 0=ASCII,1=?,6=query,7=automatic -
F9 Proportion statistic 0-100, default 20 -
FA Invalid distance (cm) 10-1000, default 30 -
FB Percentage (%) 10-100, default 30 -
DF Firmware upgrade 1 -
FE Query parameters 0 Query all parameters
I wrote a simple Arduino library to communicate with the module, send frames to configure the device and receive frames with measurement data.
Firmware
I soldered a connector to the SWD interface and dumped the firmware. No time/motivation yet to reverse engineer it.
Serial interface
The module communicates at 115200 by default. This is slightly fast for the SoftSerial library on ESP8266 and some incoming frames will not be recognised.
