PowerLight
Project PowerLight
Shows mix of dutch electrical power generation as a pie chart on a LED ring
Last Update 2024-05-16
The concept
Show the current dutch electrical power generation-mix as pie chart on a LED ring light, with colors representing fractions of a specific power generation source.
For example:
  • yellow: solar
  • blue: wind
  • red: fossil
  • green: nuclear
  • purple: other/waste
Power generation data
ENTSO-E data
  • B01 (biomass): always 0, not useful
  • B02: not available
  • B03: not available
  • B04 (fossil hard coal): useful
  • B05 (fossil gas): useful
  • B06: not available
  • B07: not available
  • B08: not available
  • B09 (geothermal): not available
  • B10 (hydro): not available
  • B11 (hydro): always 0
  • B12 (hydro): not available
  • B13 (marine): not available
  • B14 (nuclear): useful
  • B15 (other renewable): not available
  • B16 (solar): hugely underreported, *not* useful
  • B17 (waste): useful
  • B18 (wind offshore): useful
  • B19 (wind onshore): useful
  • B20 (other): useful
  • B16 (solar)
Data schedule
The model I use for the energy generation mix of the Netherlands
Main points relevant for me:
In my backend application, energy generation fractions are calculated as follows:
  • solar = B16 (from the time-shifted forecast document A69)
  • wind = B18 (offshore, from generation document A75) + B19 (onshore, from time-shifted forecast document A69)
  • fossil = B04 (gas) + B05 (coal)
  • nuclear = B14
  • waste = B17
  • other = B20
In the end, all of the electrical generation data used in my backend application is ENTSO-E data.
Data model behind CO2monitor.nl
Analysis:
  • Much of the data comes from ENTSO-E, except for at least solar, wind, biomass, WKK
  • Biomass data seems to follow the coal data exactly in shape. The sum of the biomass and coal numbers at CO2monitor equal exactly the ENTSO-E hard coal number.
  • CO2monitor must be assigning some fraction of the ENTSO-E hard-coal number to biomass, it is unknown how they arrive at this fraction
  • The biomass fraction seems to be 1295/2740 = 47.3% (data from 18 november 2023)
Some data from CBS on energy use for electricity production in 2022: https://opendata.cbs.nl/statline/#/CBS/nl/dataset/80030NED/table?fromstatweb
  • total energy from coal: 53315 TJ
  • total energy from biomass: 34798 TJ
This means a ratio of 39.5% biomass vs (biomass + coal), not exactly the CO2monitor number, but on the same order
Nederlands energie dashboard API
Notes:
  • Het content-type is standaard application/json+ld, je ontvangt dan JSON met 'linked data', data is dan gewrapped in een andere structuur. Content-type application/json werkt ook.
  • De argumenten zijn case-sensitive, argumenten moeten met kleine letter beginnen. De documentatie is inconsistent op dit punt (toont hoofdletters).
  • De volgorde van argumenten is belangrijk, een verkeerde volgorde leidt tot time-outs. De 'juiste' volgorde is onduidelijk, volg de voorbeelden. In ieder geval 'point' of 'validfrom' eerst.
  • Het 'utilization' endpoint levert altijd tijdreeksen op. De fijnste resolutie waarmee je een tijdreeks kan opvragen is een dag. De API heeft geen specifieke mogelijkheid voor opvragen van de meest recente / actuele waarde. Voor verschillende bronnen moet je losse calls maken (let op: rate limit)
Mapping van ned.nl data naar energie-ring:
  • solar = 2 (solar)
  • wind = 1 (wind) + 51 (offshoreC)
  • fossil = 18 (FossilGasPower) + 19 (FossilHardCoal) = zelfde data als ENTSO-E (minus de aanname over de biomassa-fractie?)
  • nuclear = 20 (Nuclear) = zelfde data als ENTSO-E
  • waste = 21 (WastePower) = zelfde data als ENTSO-E
  • other = 26 (OtherPower)
Wat nog onduidelijk is / beetje raar:
  • Bronnen lijken overlap te hebben, hoe voorkom je dat je dingen dubbel telt?
    • Bijvoorbeeld biomass, bio-oil, bio-methane, "biomasspower", wood en cofiring, gaat allemaal over biomassa.
  • Onderscheid verwarming / elektriciteitsopwek
    • Other vs OtherPower, is de eerste inclusief warmte, en de tweede alleen elektriciteit?
  • Er zijn verschillende modellen voor offshore-wind, maar juist de onshore-wind heeft veel onzekerheid
  • Hoe werkt het zonne-opwekmodel?
  • Bron 'All' is *alleen* hernieuwbare fractie?
Parts:
Connecting it:
  • Solder the straight pin headers that came with it on the wemos d1 mini
  • Solder the angled pin to the LED ring
  • Connect the dupont cable:
    • Wemos 5V goes to 5V on the LED ring
    • Wemos GND goes to GND on the LED ring
    • Wemos D3 goes to DI on the LED ring
    • Wemos D2 goes to DO on the LED ring
Diffuser: https://www.thingiverse.com/thing:751894 resize to 89x89x8 mm
  • The backend part that collects the power generation data, written in Java, running on a VPS
  • The light part that visualizes the power generation as fractions on a LED ring, running on an Arduino
Backend
Runs as a REST-like resource, with the following endpoints:
Returns JSON-structures like:
  "time": 1700728200,
  "datetime": "2023-11-23T09:30:00+01:00",
  "total": 13552,
  "mix": [
    { "id": "solar", "power": 1232, "color": "#FFFF00"},
    { "id": "wind onshore", "power": 4241, "color": "#0000FF"  },
    { "id": "wind offshore", "power": 2963, "color": "#0000FF"  },
    { "id": "fossil gas", "power": 2264, "color": "#FF0000"  },
    { "id": "fossil coal", "power": 2051, "color": "#FF0000"  },
    { "id": "nuclear", "power": 483, "color": "#00FF00"  },
    { "id": "waste", "power": 70, "color": "#FF00FF"  },
    { "id": "other", "power": 248, "color": "#FF00FF"  }
  • time is a unix time stamp in seconds, representing the end of the 15-minute period that the power figures refer to
  • dateime is ta user-readable time stamp, in dutch local time + offset
  • total is the total most recent electrical power (megawatt), suitable for display (on a numeric display inside the ring for example)
  • mix is an array of power sources, each with:
    • a short unique id
    • most recent known power (megawatt)
    • hex color, for display on the led ring
  "current": { "date": "2022-10-30","price": 32.02 },
  "day-ahead": [
    { "date": "2022-10-31", "price": 62.631 },
    { "date": "2022-11-01", "price": 49.293 }
Display
LED ring energy mix
Hardware that I used:
  • Wemos D1 mini, contains an ESP8266 + USB-serial converter
  • 24-led pixel ring, for example this one https://nl.aliexpress.com/item/32963152993.html
  • "dupont"-cable, you need 4 wires
    • wemos 5V to LED ring 5V
    • wemos GND to LED ring GND
    • wemos D3 to LED ring DI
    • wemos D2 to LED ring DO
Firmware installation:
  • compiled using platformio
  • clone the code from github, enter the PowerLight directory
  • pio run -t upload
Configuration:
  • connect over WiFi to the "ESP-POWERLIGHT" network (no password)
  • open page at 192.168.4.1
  • enter WiFi credentials (select a network + password)
LED ring price clock
  • LED ring with 24 coloured leds, 2 leds per hour
  • colour indicates relative price, green = low, red = high
  • indicate current time by making the corresponding LED extra bright
Interesting links:
ElectricityPrice
T-Display
SHA-badge
Micropython:
  • ++ possibly quick development, script can be shared with other people
  • ++ has working libs for fetching HTTP, decoding JSON, controlling the display
  • -- script needs frequent garbage collection to avoid crashing?
  • -- unclear how to get a python script on this thing
  • -- sha badge firmware bootloops, currently unusable to me
Arduino:
  • ++ I know this environment, don't have to debug existing bootlooping firmware, no compiler setup required
  • ++ Already have HTTP and JSON working on Arduino
  • ++ Code starts immediately, no user interaction required
  • -- not sure if there is a usable epaper driver
