GorbaDisplay
| Project GorbaDisplay | |
| Bestand:Whyunopicture.jpg | |
| Public transport LED display | |
| Status | Initializing |
| Contact | bertrik, User:Eloy |
| Last Update | 2023-08-02 |
This project is about reverse engineering a former public transport LED display. It consists of Z panels of each X * 16 LEDs. Each panel has 16 amber LEDs vertically.
The plan is to make the display fully addressable as a bitmap display over a network connection, preferably with individually controllable brightness.
- a control board, with logic to receive (for example) text messages over a serial connection and convert them to a bitmap display on the display board
- a display board, with logic to light up each LED
Between them is a 14-pin connector, probably carrying the low-level LED control signals.
The display board consists of several (4?) panels of LEDs.
Theory of operation
My guess this is probably another row-multiplexed display. The display can light up one row at a time. By quickly lighting up each row in succession, the illusion to a human observer is that all LEDs are controlled simultaneously.
The display board contains the followings integrated cicruits:
- 74HC541, an octal buffer/line driver, probably buffers all signals coming in from the 14-pin connector to the rest of the electroncis
- 74HC238, a 3-to-8 line decoder/demultiplexer, probably selects which row is currently being lit up
- group of 4x IRF7425, power MOSFET, probably drives a row of LEDs
- a whole bunch of TPIC6C596, 8-bit shift register, probably drives the columns inside one row of LEDs
The demultiplexer handles only 3 bits, perhaps there are two of them to handle 16 rows: one for the top 8 rows and one for the bottom 8 rows.
14-pin connector
- 1 - power or ground
- 2 - power or ground
- 3 - ?
- 4 - ?
- 5 - A1 of multiplexer
- 6 - A2 of multiplexer
- 7 - ?
- 8 - ?
- 9 - ?
- 10 - A0 of multiplexer
- 11 - ?
- 12 - SRCK, data clock
- 13 - power or ground
- 14 - power or ground
There are possibly pins for:
- row select, bit 0
- row select, bit 1
- row select, bit 2
- row select, bit 3
- row-enable
- shift register data
- shift-register clear
- shift-register data
- analog LDR value
- remote control input
- power pin
- power pin
- ground pin
- ground pin
