PowerLight
Project PowerLight
Shows mix of dutch electrical power generation as a pie chart on a LED ring
Last Update 2023-06-17
The concept
Show the current dutch electrical power generation-mix as pie chart on a LED ring light, with colors representing fractions of a specific power generation source.
For example:
  • yellow: solar
  • blue: wind
  • red: fossil
  • green: nuclear
  • purple: other/waste
Power generation data
ENTSO-E data
  • B01 (biomass): always 0, not useful
  • B02: not available
  • B03: not available
  • B04 (fossil hard coal): useful
  • B05 (fossil gas): useful
  • B06: not available
  • B07: not available
  • B08: not available
  • B09 (geothermal): not available
  • B10 (hydro): not available
  • B11 (hydro): always 0
  • B12 (hydro): not available
  • B13 (marine): not available
  • B14 (nuclear): useful
  • B15 (other renewable): not available
  • B16 (solar): hugely underreported, *not* useful
  • B17 (waste): useful
  • B18 (wind offshore): useful
  • B19 (wind onshore): useful
  • B20 (other): useful
  • B16 (solar)
A model for the energy generation mix of the Netherlands
For me, the most insightful information came from this article by Bert Hubert: https://berthub.eu/articles/posts/dutch-electrical-power-figures-2/
Main points relevant for me:
In my backend application, energy generation fractions are calculated as follows:
  • solar = B16 (from the time-shifted forecast document A69)
  • wind = B18 (offshore, from generation document A75) + B19 (onshore, from time-shifted forecast document A69)
  • fossil = B04 (gas) + B05 (coal)
  • nuclear = B14
  • waste = B17
  • other = B20
In the end, all of the electrical generation data used in my backend application is ENTSO-E data.
Data schedule
Parts:
Connecting it:
  • Solder the straight pin headers that came with it on the wemos d1 mini
  • Solder the angled pin to the LED ring
  • Connect the dupont cable:
    • Wemos 5V goes to 5V on the LED ring
    • Wemos GND goes to GND on the LED ring
    • Wemos D3 goes to DI on the LED ring
    • Wemos D2 goes to DO on the LED ring
Diffuser: https://www.thingiverse.com/thing:751894 resize to 89x89x8 mm
  • The backend part that collects the power generation data, written in Java, running on a VPS
  • The light part that visualizes the power generation as fractions on a LED ring, running on an Arduino
Backend
Runs as a REST-like resource, with the following endpoints:
Returns JSON-structures like:
  "time": 1657057500,
  "total": 9122,
  "mix": [
    { "id": "solar", "power": 0, "color": "#FFFF00"},
    { "id": "wind", "power": 4, "color": "#0000FF"},
    { "id": "fossil", "power": 86, "color": "#FF0000"},
    { "id": "nuclear", "power": 5, "color": "#FF00FF"},
    { "id": "other", "power": 4, "color": "#444444"},
    { "id": "waste", "power": 1, "color": "#444444"}
  • time is a unix time stamp in seconds, representing the end of the 15-minute period that the power figures refer to
  • total is the total most recent electrical power (megawatt), suitable for display (on a numeric display inside the ring for example)
  • mix is an array of power sources, each with:
    • a short unique id
    • most recent known power (megawatt)
    • hex color, for display on the led ring
  "current": { "date": "2022-10-30","price": 32.02 },
  "day-ahead": [
    { "date": "2022-10-31", "price": 62.631 },
    { "date": "2022-11-01", "price": 49.293 }
Display
LED ring energy mix
Hardware that I used:
  • Wemos D1 mini, contains an ESP8266 + USB-serial converter
  • 24-led pixel ring, for example this one https://nl.aliexpress.com/item/32963152993.html
  • "dupont"-cable, you need 4 wires
    • wemos 5V to LED ring 5V
    • wemos GND to LED ring GND
    • wemos D3 to LED ring DI
    • wemos D2 to LED ring DO
Firmware installation:
  • compiled using platformio
  • clone the code from github, enter the PowerLight directory
  • pio run -t upload
Configuration:
  • connect over WiFi to the "ESP-POWERLIGHT" network (no password)
  • open page at 192.168.4.1
  • enter WiFi credentials (select a network + password)
LED ring price clock
  • LED ring with 24 coloured leds, 2 leds per hour
  • colour indicates relative price, green = low, red = high
  • indicate current time by making the corresponding LED extra bright
ElectricityPrice
T-Display
SHA-badge
Micropython:
  • ++ possibly quick development, script can be shared with other people
  • ++ has working libs for fetching HTTP, decoding JSON, controlling the display
  • -- script needs frequent garbage collection to avoid crashing?
  • -- unclear how to get a python script on this thing
  • -- sha badge firmware bootloops, currently unusable to me
Arduino:
  • ++ I know this environment, don't have to debug existing bootlooping firmware, no compiler setup required
  • ++ Already have HTTP and JSON working on Arduino
  • ++ Code starts immediately, no user interaction required
  • -- not sure if there is a usable epaper driver
