PowerLight
Project PowerLight | |
Show energy mix of dutch power generation as a pie chart on a LED ring | |
Contact | bertrik |
Last Update | 2022-07-05 |
1. The concept
Draw the current power generation-mix as a kind of pie chart on a LED ring light, with colors representing a fraction of a specific power generation source.
For example:
- blue: wind power
yellow: solar powersee belowgreen: power from biomasssee below- purple: power from nuclear
- red: fossil
- grey: other
2. Power generation data
This is a bit of a problem. There is no open data available with reasonably complete power generation fractions!
2.1. The solar power problem
In particular the solar power fraction is incomplete, but also the biomass figures are missing. See:
- https://berthub.eu/articles/posts/dutch-electrical-power-figures-2/ (text)
- https://energy-charts.info/charts/energy_pie/chart.htm?l=en&c=NL note how the solar part is tiny
There is a model to estimate this fraction at https://api.netanders.io/, however you cannot use this API without a key (and you can't just get a key).
3. Hardware
Parts:
- LED ring light https://nl.aliexpress.com/item/1005003798658173.html
- Wemos D1 mini with an ESP8266
4. Software
- backend part that collects the power generation data
- light part that visualizes the power generation as fractions on a LED ring
4.1. Backend
To be implemented, this will probably run on my web page stofradar.nl. Some REST-like resource like http://stofradar.nl:9001/power/latest
Returns a JSON-structure like:
{ "time": 1656490664, "total": 1600, "energymix": [ { "id": "solar", "percent": 40, "color": "#FFFF00"}, { "id": "wind", "percent": 25, "color": "#0000FF"}, { "id": "fossil", "percent": 25, "color": "#FF0000"}, { "id": "biomass", "percent": 5, "color": "#00FF00"}, { "id": "nuclear", "percent": 5, "color": "#FF00FF"} ] }
- time is a unix time stamp in seconds, representing the end of the period that the power figures refer to
- total is the total current electrical power usage, suitable for display (inside the ring for example), unit yet to be determined
- energymix is an array of percentages along with their colors, to be displayed clockwise on the led ring, mandatory fields
- percent
- color
4.2. Light
Source code: https://github.com/bertrik/PowerLight
