Pasjesprinter
Revision as of 21:54, 12 April 2022 by Bas (talk | contribs)
Project Pasjesprinter
Een printer, maar dan voor pasjes
Contact sebastius
Last Update 2022-04-12
Handleiding
File:Evolis Pebble 3 Printer User Manual.pdf
Aansluiten
  • 24V DC adapter, center positive, 24V 3A.
  • USB B en Centronics als mogelijkheden. Gebruik USB ;)
Repair
Bij printer #3 was de USB connector naar binnen geramd, met schade aan de weerstanden en caps. Caps gerecycled, weerstanden 18ohm vervangen voor 22ohm.
De grote elko stond bol, ook vervangen.
Drivers
Evolis website, Pebble 4 drivers werken goed.
Firmware Update
Firmware downloaden naar een Windows 7 VM: https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/ , eerst de driver installeren uit de zip en dan de firmware update runnen. Laatste versie is 6.14 .
Specs
  • Print speed 150 cards/hour in full color (YMCKO), Up to 1000 cards/hour in monochrome1
  • Resolution 300 dpi (11,8 dots/mm)
  • Card types: PVC, Composite PVC, PET, ABS and special varnished plastic cards
  • Card format: ISO CR-80 - ISO 7810 (53,98 mm x 85,60 mm - 3.375" x 2.125")
  • Card thickness: From 0,25 mm (10 mil) to 1 mm (40 mil)
  • Card feeder capacity: 300 cards (0,25 mm- 10 mil) - 100 cards (0,76 mm - 30 mil)
  • Card output hopper capacity: 150 cards (0,25 mm - 10 mil) - 50 cards (0,76 mm - 30 mil)
  • Printer size: Height: 192 mm (7.55"), Length: 396 mm (15.59"), Width: 235 mm (9.25") - Printer weight: 5,9 Kg (13 lbs)
  • Environmental: Min / max operating temperature: 15° / 30° C (59° / 86° F) - Humidity: 20% to 65% non-condensing - Min / max storage temperature: -5° / +70° C (23° / 158° F) - Storage humidity: 20% to 70% non-condensing
Accessoires
Monochrome ribbons
  • P/N: R2011 Black ribbon 1000 cards/roll
  • P/N: R2012 Blue ribbon 1000 cards/roll
  • P/N: R2013 Red ribbon 1000 cards/roll
  • P/N: R2014 Green ribbon 1000 cards/roll
  • P/N: R2015 White ribbon 1000 cards/roll
  • P/N: R2016 Gold ribbon 1000 cards/roll
  • P/N: R2017 Silver ribbon 1000 cards/roll
  • P/N: R2018 Scratch off ribbon 1000 cards/roll
  • P/N: R2019 BlackWAX Black ribbon 1000 cards/roll
Multi-Panels Ribbons
  • P/N: R3011 5 Panel Color Ribbon - YMCKO (Yellow, Magenta, Cyan, Black TT and Varnish) 200 cards/ribbon
  • P/N: R3012 2 Panel Monochrome Ribbon - KO (Black TT and Varnish) 500 cards/roll
  • P/N: R3013 Half-Panel Color Ribbon - YMCKO (Yellow, Magenta, Cyan, Black TT and Varnish) 400 cards/roll
Hologram ribbon
  • P/N: R4001 Optoseal® Hologram Ribbon 350 cards/ribbon
Cleaning accessories
  • P/N: A5011 UltraClean Cleaning Kit (for complete cleaning of the printer)5 pre-saturated cleaning cards, 5 swabs, 1 box of 40 pre-saturated wipes
  • P/N: A5002 PrinterClean Cleaning kit (for cleaning of the transport rollers)50 pre-saturated cleaning cards
  • P/N: A5003 HeadClean Cleaning kit (for cleaning the print head)25 swabs
  • P/N: A5004 DustClean Cleaning kit (for maintaining the cleaning roller)1 box of 40 pre-saturated wipes
