TTNHABBridge
Project TTNHABBridge | |
A software bridge between TheThingsNetwork and the UKHAS high-balloon network | |
Status | Completed |
Contact | bertrik |
Last Update | 2021-11-10 |
This software is a bridge application that accepts high altitude balloon telemetry data from TheThingsNetwork and forwards it to the habhub tracker website.
In short, the idea is:
- you attach a LoRaWAN transmitter to the balloon, which been pre-configured with a set of keys generated by the TTN
- the balloon broadcasts its telemetry every once in a while (say a few times per minute) and this is picked up by one or more TTN gateways which forward into the TTN infrastructure
- the bridge software converts each telemetry packet according to 'UKHAS' conventions and forwards it to the habitat.habhub.org server
- the bridge software also forwards the TTN gateway locations, so they also appear on the map, along with their name / EUI and antenna altitude
- the habitat.habhub.org server still sees the same messages like it would if there were many traditional receivers, so doesn't need any modification
Source code
Using this source code, the basic functionality works.
There is no user guide yet, but the .properties settings file has a one-line comment explaining what each setting does.
Building the software
Steps (on Debian Linux):
- install a java-11 JDK
sudo apt install openjdk-11-jdk
- clone the software from github
git clone https://github.com/bertrik/ttnhabbridge
- enter directory ttnhabbridge
cd ttnhabbridge
- run the gradle script to build the executable
./gradlew assemble (Linux) gradlew assemble (Windows)
- the executable is now available at ttnhabbridge/build/distributions/ttnhabbridge.tar and ttnhabbridge.zip
Running the software
- extract either the tar (Linux) or zip (Windows) that was generated in the build step
- run it once to generate the initial configuration file, this file is called ttnhabbridge.properties
cd ttnhabbridge bin/ttnhabbridge
- stop it, using CTRL-C
- edit the ttnhabbridge.properties configuration file with a text editor, enter your application name, keys, payload encoding, etc.
- run it again and verify that the program starts correctly with the new properties file
Design
Main process
- once we get data:
- for each TTN gateway that received the data:
- send a listener info document and a listener telemetry document to the habhub server
- send the payload telemetry (ASCII sentence) to the habhub server
Habitat uploader
The habitat interface is accessed as a REST service.
payload upload
The application communicates with the habhub server using a HTTP interface, performing a PUT to a certain URL with a certain content:
- the URL is http://habitat.habhub.org/habitat/_design/payload_telemetry/_update/add_listener/<doc_id>
- the <doc_id> is created from the telemetry sentence by doing ASCII to BASE64 conversion, then hashing using SHA-256 and encoding as ASCII-hex (as LOWER case!).
- the HTTP method is a PUT with the following headers:
- "Accept: application/json"
- "Content-Type: application/json"
- "charsets: utf-8"
- The contents of the PUT is the following JSON structure
{ "data": { "_raw": "[base64 of telemetry sentence]" }, "receivers": { "[receiver_id]": { "time_created": "[timestamp]", "time_uploaded": "[timestamp]" } } }
listener upload
To figure out how to upload information about the receiver station, I captured some traffic between dl-fldigi and habitat, the following happens:
- a GET is done on http://habitat.habhub.org/_uuids?count=100, this returns a list of 100 UUIDs, where a UUID is the lower-case ascii hex representation of 16 bytes.
- a PUT is done with a "listener_information" doc to /habitat/<the first UUID>
- a PUT is done with a "listener_telemetry" doc to /habitat/<the second UUID>
This is implemented with an expiring cache, so listener information/telemetry is uploaded regularly (say every 20 minutes) but not with *every* payload telemetry.
Payload encoder/decoder
The bridge application currently allows the following encodings for the telemetry data, configurable in the application properties:
- 'cayenne' (recommended): "cayenne" encoding
- 'sodaqone': SodaqOne universal tracker conventions.
- 'json': a JSON encoded format
See the table and example below to know which fields are required to construct the habitat ASCII sentence from the LoRa data payload sent by your tracker.
$$ttntest1,64,20:41:10,52.022100,4.693100,20.0,14.0,3.88*1C8A
Field value | SodaqOne raw | JSON | Cayenne | Remark |
ttntest1 | TTN node name | TTN node name | TTN node name | TTN node name |
64 | LoRaWAN FCNT | LoRaWAN FCNT | LoRaWAN FCNT | Frame count |
20:41:10 | field 0 | TTN metadata time | TTN metadata time | TTN metadata time |
52.022100 | field 3 | "lat" | see below | latitude (degrees) |
4.693100 | field 4 | "lon" | see below | longitude (degrees) |
20.0 | field 5 | "gpsalt" | see below | altitude (meters) |
14.0 | field 2 | "temp" | see below | temperature (degrees Celcius) |
3.88 | field 1 | "vcc" | see below | battery voltage (volts) |
The field 1C8A is the CCITT-CRC16 over the characters between $$ and *, interpreted as bytes using US-ASCII encoding
Listener cache
Listener information / telemetry is sent only:
- when this is the first time we are sending something for this listener
- when it has been more than X minutes ago that we sent listener information / telemetry for this listener, where X is typically 10 minutes or so.
Helpful links
Tracker configuration for the TTN-HAB bridge software
- setup your LoRaWAN device for use with TheThingsNetwork
- create a payload configuration document on the habhub.org webpage
- download, configure and run the ttnhabbridge software
Setting up the tracker for TTN
- specifically for the SodaqOne, the EUI (LoRaWAN hardware address) is shown at startup of the tracker
- perhaps just make up your own, if you don't use an RN2483?
Create the TTN application and register your tracker with TTN (Note: this was written for the previous TTNv2 console, to be updated)
- Create an account on TTN, https://account.thethingsnetwork.org/
- Go to the TTN console and create a new application, or select an existing application you want to add the device to.
- If you use Cayenne as the payload format, you can configure this under 'Payload Formats', this allows you to view the raw payload as a kind of JSON format in the TTN console
- create a new node/device, the name needs to be equal to the habhub payload name (but cannot use uppercase characters)
- In the device settings screen:
- under 'Device EUI', fill in the EUI of your LoraWAN tracker
- under 'Activation method' choose ABP
- disable option 'Frame Counter Checks'
- click Save
- this means the "device address", "network key" and "application key"
- in case you use a SodaqOne serial debug console, type the following:
- copy the Network Session Key from the TTN console and type in the SodaqOne serial debug console 'key=<key>'
- copy the App Session Key from the TTN console and type in the SodaqOne serial debug console 'app=<key>'
- copy the device id from the TTN console and type in the SodaqOne serial debug console 'dev=<deviceid>' (is this right?)
- configure the following additional settings in the SodaqOne:
- enable GPS: 'gps=1'
- set GPS fix interval: 'fi=1'
- set GPS fix timeout: 'gft=30'
- set num coords to upload: 'num=1'
- set min GPS satellite count: 'sat=1'
- enable ABP mode (disable OTAA): 'otaa=0'
- disable ADR: 'adr=0'
- set spreading factor 7: 'sf=7'
Creating a payload configuration document
Steps:
- Go to the habhub habitat website and create new payload document
- under 'payload name' fill in the callsign (e.g. 'ttntest1'), this has to match exactly with the TTN node name
- add a parser configuration, using the new format wizard
- enter the following example string: $$ttntest1,64,20:41:10,52.022100,4.693100,20.0,14.0,3.88*1C8A
- the fields are the following:
- sentence id
- time
- all of the Cayenne fields in the order they appear in the Cayenne message.
- click save
So, this contains the basic position information, plus two fields for temperature and battery level.
Configuring the TTN-HAB bridge software
- get the release zip/tar file and unzip it in some place
- make sure you have Java 8 installed
- In the bridge configuration properties file (ttnhabbridge.properties), fill in the following
- ttn.app.id with the name of your TTN application
- ttn.app.key with the key of your TTN application (you can create in the TTN console, copy it down immediately as you can't view a key later)
- ttn.payload.encoding with the type of payload encoding you use (I recommend Cayenne)
- you can probably leave the other settings at their default value
- start the bridge software from the command line, either using the .bat file (for windows) or the .sh file (for Linux)
- if you use Linux with systemd, you can use the ttnhabbridge.service file to run it as a service, see instructions inside this file
For "TheThingsStack v2" (old,no longer functional), you typically need the following configuration items:
- ttn.version = V2
- ttn.mqtt.url = tcp://eu.thethings.network
For "TheThingsStack v3" (current), you typically need the following configuration items:
- ttn.version = V3
- ttn.mqtt.url = tcp://eu1.cloud.thethings.network
