LoRa-E5-mini
| Project LoRa E5 | |
| Arduino on the LoRa-E5-mini devboard | |
| Last Update | 2021-10-18 |
The plan
- replace the original "AT" firmware with Arduino based firmware
- use the BasicMac library for LoRaWAN
- use platformio as the build system
- create some basic examples for use as a LoRaWAN node on TheThingsNetwork
What currently works:
- can run an Arduino program, compiling from the Arduino IDE
- blinking the LED works
- output over serial works
TODO, yet to figure out:
- add support for the Seeed LoRa E5 mini in the stm32 package
- get communication going using the internal "subghz" SPI port
- do I need to enable the APB3 clock domain?
- be careful about the SUBGHZ SPI clock in combination with SMPS mode
- get a simple transfer going that proves that meaningful data is exchanged (e.g. default sync word magic number)
- get basicmac stack working with the "subghz" SPI port (it appears communication in the Arduino version of BasicMac is done using just "SPI", see https://github.com/LacunaSpace/basicmac/blob/master/target/arduino/hal/hal.cpp#L193)
- get compilation and upload working with platformio
The hardware is the LoRa-E5 mini from seeed studio, contains the STM32WLE5JC:
- LoRa E5 Seeed studio module (just the chip): https://www.seeedstudio.com/LoRa-E5-Wireless-Module-p-4745.html
- LoRa E5 Seeed studio LoRa-E5 mini dev board: https://www.seeedstudio.com/LoRa-E5-mini-STM32WLE5JC-p-4869.html
- LoRa E5 Seeed studio wiki page: https://wiki.seeedstudio.com/LoRa-E5_STM32WLE5JC_Module/
- FCC information about the module: https://fccid.io/Z4T-LORA-E5/
Pins:
- PA4/PA5: radio rx/tx?
- PB6/PB&: serial port
- PB5: onboard LED
- PB13: onboard button ("BOOT")
- PA4: internal SUBGHZ SPI NSS, conflicts with RX/TX switch?
- PA5: internal SUBGHZ SPI SCK, conflicts with RX/TX switch?
- PA6: internal SUBGHZ SPI MISO
- PA7: internal SUBGHZ SPI MOSI
LoRa modem
It appears the LoRa functionality is exposed through an internal SPI bus, called SUBGHZSPI in the datasheet.
Also, there are some pins to control the radio path.
Programming over SWD
Connect an ST-LINKv2 as follows:
- SWDIO to PA13
- SWCLK to PA14
- GND to GND
You may need to upgrade the firmware of your STLINKv2, mine is currently at V2J38S7.
Initial experimental firmware can be found at: https://github.com/bertrik/lora-e5
- blinky example, the most basic of all sketches which makes a LED blink demonstration of successful download of an Arduino program
- helloworld example, sends a text over the serial port
These examples still uses the Arduino IDE, with a 'generic' STM32WLE5JCI.
There appears to be support for various kinds of WL55 boards in the stm32duino project: https://github.com/stm32duino/Arduino_Core_STM32/blob/main/boards.txt
Support for a generic WLE5JCI board here in the stm32duino archive: https://github.com/stm32duino/Arduino_Core_STM32/blob/main/variants/STM32WLxx/WL54JCI_WL55JCI_WLE4J(8-B-C)I_WLE5J(8-B-C)I/boards_entry.txt#L62
How to add a new variant (board): https://github.com/stm32duino/wiki/wiki/Add-a-new-variant-(board)
Experimental development environment
This uses my own fork, which will include support for the Seeed LoRa E5 mini.
- Install Arduino IDE 1.8.16, from https://www.arduino.cc/en/software
- Add this board URL (under File / Preferences / Additional board URLs):
https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json
- Under menu Tools/Board/Boards manager, search for STM32 and install 'STM32 MCU based boards'
- Clone my Arduino_Core_STM32 repo into ~/Arduino/hardware
- cd ~/Arduino/hardware
- mkdir -f stm32
- cd stm32
- git clone https://github.com/bertrik/Arduino_Core_STM32
- Select the correct board:
- Under menu Tools/Board/STM32 boards .... (sketchbook), choose 'Generic STM32WL series' from 'Generic STM32WL series'
- Under menu Tools/Board part number, choose 'Seeed Studios LoRa E5 mini'
- Install STM Cube for the upload tools, they are called en.stm32cubeprg-lin_v2-8-0_v2.8.0.zip
- Run STM Cube to remove read protection (and erase the device)
- TODO: document, or see the Seeed page
Now you can:
- Load the helloworld.ino file into the Arduino IDE:
- Compile and upload with ctrl-U
- Open serial port with ctrl-shift-M and see that serial messages are coming in
Node configuration in TheThingsNetwork
