LoRa-E5-mini
Project LoRa E5 | |
Arduino on the LoRa-E5 module | |
Contact | bertrik |
Last Update | 2021-10-08 |
The plan
- replace the original "AT" firmware with Arduino based firmware
- use the BasicMac library for LoRaWAN
- use platformio as the build system
- create some basic examples for use as a LoRaWAN node on TheThingsNetwork
The hardware is the LoRa-E5 module from seeed studio, contains the STM32WLE5JC:
- LoRa E5 module (just the chip): https://www.seeedstudio.com/LoRa-E5-Wireless-Module-p-4745.html
- LoRa E5 mini dev board: https://www.seeedstudio.com/LoRa-E5-mini-STM32WLE5JC-p-4869.html
- LoRa E5 wiki page: https://wiki.seeedstudio.com/LoRa-E5_STM32WLE5JC_Module/
- FCC information about the module: https://fccid.io/Z4T-LORA-E5/
Programming an STM32 is done with pins SWDIO (PA13), SWCLK (PA14), GND and VCC
https://github.com/bertrik/lora-e5
There appears to be support for various kinds of WL55 boards: https://github.com/stm32duino/Arduino_Core_STM32/blob/main/boards.txt
Support for this board in this archive: https://github.com/dolfandringa/Arduino_Core_STM32/blob/master/variants/STM32WLxx/WL54JCI_WL55JCI_WLE4J(8-B-C)I_WLE5J(8-B-C)I/boards_entry.txt#L62 ???
Development environment
- Install Arduino IDE, from https://www.arduino.cc/en/software
- Add a board URL: https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json
- Under menu Tools/Board/Boards manager, search for STM32 and install 'STM32 MCU based boards'
- Under menu Tools/Board/STM32 boards, choose 'Generic STM32WL series', then 'Generic STM32WL series'
- Under menu Tools/Board part number, choose Generic WLE5JCIx'
Load the .ino file. Compile with ctrl-R.
Node configuration in TheThingsNetwork
