Esp32cam
Revision as of 14:49, 31 July 2021 by Bertrik Sikken (talk | contribs) (Hardware)
Project ESP32-CAM
Cheap webcams with Wifi, what could possibly go wrong?
Contact noopwafel, bertrik
Last Update 2021-07-31
It's an ESP32 board with a camera, running a web server, so it acts as an inexpensive webcam.
To install the camera:
  • flip the black part of the camera connector 90 degrees so it points up
  • place the camera connector, contacts towards the PCB, camera facing up
  • gently slide the connector in place (about 2 or 3 mm of travel), e.g. pushing with the screw driver onto the rigid part of the camera connector towards the white part of the PCB connector
  • flip the black part of the connector back into the flat position.
Pins (ESP32 cam to USB serial converter):
  • ESP-32 5V to USB serial 5V
  • ESP-32 GND to USB serial GND
  • ESP-32 UAR to USB-serial TX
  • ESP-32 UAT to USB-serial RX
  • ESP-32 IO0 looped to ESP-32 GND (they are next to each other), you can use a jumper or a dupont wire. CLOSED for flashing, OPEN for running.
platformio
The CameraWebServer example can be compiled as a platformio project: https://github.com/bertrik/CameraWebServer
To build the code, clone the git repo above, cd into it, then type
 pio run
To upload it to the board (put a jumper between IO0 and GND):
To watch the debug output (remove the jumper):
 pio device monitor
Platformio can be installed on a Debian Linux system as follows:
 sudo apt install python-pip
 sudo pip install platformio
 pio upgrade
