PowerMeter
Revision as of 22:38, 2 December 2012 by FooBar (talk | contribs) (Created page with "{{Project |Name=PowerMeter |Status=in progress |Contact=User:FooBar }} In the old hackerspace we had real-time graphs of our power-usage. In the new space at the Spoorlaan w...")
Project PowerMeter
Status in progress"in progress" is not in the list (Proposed, Initializing, In progress, Completed, Stalled, Abandoned) of allowed values for the "Project Status" property.
Contact User:FooBar
Last Update 2012-12-02
In the old hackerspace we had real-time graphs of our power-usage. In the new space at the Spoorlaan we currently don't have this yet. While it's inpossible to monitor all the power-usage by the space, as we share a lot of infrastructure with the rest of the building.
We will however be monitoring the power-usage of the main workshop space. In this room there are 3 different 16A groups (currently only 2 connected). These groups terminate in their own fusebox with a KWh meter which has a pulse-port.
These pulse-ports are connected to an arduino nano in the server-room. This arduino will then provide pulse-data on the usb port.
Current status:
  • Arduino connector board: Done
  • Arduino code/logic: Done
  • Wiring from serverroom to KWh-meters: Done
  • Wiring everything together: TODO
TODO:
  • Get cable glands (Wartels)
  • Get UTP splitter
  • Wire everything up
  • Create scripts/graphs
  • Setup reverse proxy config
