RGB64x32MatrixPanel
Versie door Costyn van Dongen (overleg | bijdragen) op 25 sep 2020 om 15:57 (Initial)
(wijz) ← Oudere versie | Huidige versie (wijz) | Nieuwere versie → (wijz)
RGB64x32MatrixPanel on ESP32
For a friend I'm making a RGB LED panel, and need to pull some social media numbers and display them on the panel.
For this I wanted an ESP32 so it could do HTTP REST calls over wifi. I came across this library for efficiently talking to HUB75 RGB panels on an ESP32:
https://github.com/mrfaptastic/ESP32-RGB64x32MatrixPanel-I2S-DMA
Parts List
MCU
Platformio.ini
[common_env_data] lib_deps = Adafruit GFX Library Adafruit BusIO Wire FastLED [env:ttgo-t1] platform = espressif32 board = ttgo-t1 board_build.mcu = esp32 board_build.f_cpu = 240000000L framework = arduino upload_protocol = esptool upload_port = /dev/cu.SLAB_USBtoUART upload_speed = 1500000 monitor_speed = 115200 lib_deps = ${common_env_data.lib_deps}
