EspNowAudio
Revision as of 13:37, 17 March 2020 by Bertrik Sikken (talk | contribs)
Project EspNowAudio
Status Initializing
Last Update 2020-03-17
What
The idea is to experiment a bit more with ESP now, in particular in combination with audio transfer.
Stuff to learn:
Possible end result: A kind of zero-standby power intercom. When you press the button, an ESP8266 is powered up. It immediately starts transmitting audio from a digital I2S microphone over ESP now. The receiving end will probably be an ESP32, that receives the ESP now audio and converts into a standardized audio-over-ip protocol, e.g. VBAN.
Plans:
  • build an Arduino playground project so I can access the API from the command line and play with it
  • start with an ESP32 + INMP441
  • build a framework to stream the data and determine stream rate:
    • queue is filled with random data
    • queue is emptied by an espnow send process running in the main loop()
    • espnow completion callback notifies when next packet can be sent
  • investigate I2S communication from a microphone on an ESP8266
  • convert espnow data to UDP/VBAN on the receiving end
  • convert UDP/VBAN to audio on laptop
Related interesting stuff:
Result
ESP NOW broadcast just seems to work fine (not sure what prevented me from making it work earlier). I've fixed the WiFi channel to 1.
On the receiving side, I use an ESP32. On the sending side, I use an ESP8266:
  • init the esp now library
  • add the broadcast address as a peer
  • send a message
  • that's it!
Transmission appears to be very fast, taking less than a millisecond for 10 messages in a row. However, with broadcast, the sending side does not receive (or wait for) any acknowledgements, the tx callback just reports the broadcast address, the rx callback reports nothing.
References
