EspNowSkip
Project EspNowSkip | |
Music skip button based on ESP-Now protocol | |
Status | Completed |
Contact | bertrik, jelly |
Last Update | 2020-02-09 |
Uitvoering | Skip | Wifiskip | EspNowSkip | Skipknop |
Gemaakt | 2013 | 2015 | 2018/2019 | 2020 |
Status | Verouderd | Onbekend | In gebruik | In gebruik |
The current ESP-Now skip button prototype needs only about 200 ms after wakeup to send a message and return to deep sleep again.
Capacitor calculation
C = I . dT / dV
Battery life
Source code
It contains the following programs:
- skipbutton.ino: an Arduino program running on the button part (slave, on an ESP8266) which sends the skip message
- skipreceiver.ino: an Arduino program running on the receiver part (master, on an ESP32) which receives the skip message
EspNowSkip protocol
It works like this:
- there are two roles:
- a single central "master" node
- one or more "slave" skip-buttons
- when the skip button is pressed, the ESP8266 resets and starts running, reads the last known ESP-Now channel and MAC address from EEPROM and sends the "SKIP" message
- if the skip button doesn't receive an ACK from the central node, it starts a kind of discovery to re-establish the channel and MAC address of the central node
- the discovery procedure tries to find the central node by doing an AP scan, the AP name is the only thing that needs to be agreed upon in advance between master and slave code
- in the list of the APs, the slave node finds the SSID belonging to the central node, then it also knows the wifi channel and MAC address of the central node
- the slave node stores both wifi channel and MAC address in (emulated) EEPROM and goes back to sleep
The data we send is an MQTT-like topic + message, for example
revspace/button/skip jump_fwd
Skip protocol
Classic HTTP GET
where
Example:
JSON Protocol
To skip, send a HTTP POST to:
http://jukebox.space.revspace.nl:9000/jsonrpc.js
with content
Expect a result like:
More buttons modification
In its current form, the skip button can only skip.
To get more functionality (e.g. volume up/down) the following could be done:
- add two more buttons, volume up and volume down
- when a volume button is pressed, it connects the positive battery terminal to a ESP8266 input pin
- also it powers up the ESP8266 by connecting the positive battery terminal to the ESP8266 Vcc (through a low-drop schottky diode, e.g. BAT43)
- the software is modified to check the input pin upon startup, if the pin is active, it performs the action for volume up/down, instead of the action for skip
- problem (?): the ESP8266 does not have a built-in pull-down, so the pin level is undefined when the button is not pressed -> perhaps add an external pull-down?
- alternatively, the pins do have a built-in pull-up, so we could perhaps wire it up so we switch the ground pin instead of the Vcc pin
References
Future
- put it in a nicer case (ceiling cavia watches you skip)
- add more buttons besides just skipping!
More distant future:
- use ESP-Now also for other kinds of hacker space infrastructure where low-power consumption is important and/or a power wire is inconvenient: spark shack temperature for example.
- send data back to the skip button, for example we could send a "now playing" message or album art back to a SHA2017 badge and have it shown on its e-ink display. Complication: there is no easy-to-use Arduino implementation of the e-ink display.
add a supercap to the skip button, to allow a short press (e.g. 100 ms) to also be registered -> I have various types in my Samla (e.g. 0.1F 5.5V)..Not needed.
