Treinonderdelen
Project Treinonderdelen | |
Status | Initializing |
Contact | Sebastius |
Last Update | 2019-11-18 |
Catalogus
Coordinatie
Inschrijflijst
Treindisplay intern
- Beschikbaarheid
- Totale aantal: 1908 Afname mogelijk: 492 Frequentie: Per tranche
- Min. afname: 100 stuks Locatie: n.t.b.
- Specificaties
- Materiaal: Aluminium, PC, RVS
- Lengte: 707 mm Breedte: 121 mm Diepte:60 mm
Nickname | Hackerspace | How to contact | Number of units |
Sebastius | Revspace | IRC #revspace Sebastius | 3 |
Jolo | Bitlair | TBA (via polyfloyd) | 1 |
h3x4d3c1m4l | Revspace | Telegram @h3x4d3c1m4l | 2 |
minicom + Niels | Revspace | IRC #revspace minicom | 2 |
PBX | Revspace | PBX | 1 |
Bef0re | Revspace | bef0re | 3 |
Martian | TkkrLab / Hackalot | IRC #tkkrlab martian | 1 |
Archels | Hack42 | Archels in #hack42 | 1 |
Boots | nurdspace | IRC #nurds Boots | 1 |
thomas | Revspace | IRC #revspace thomastheo | 1 |
pietdv | Revspace | piet_at_devae.re | 2 |
rad0 | TechInc | ? | 1 |
Wizzup | TechInc | ? | 1 |
eightdot | Bitlair | IRC | 2 |
Wheeze_NL | RevSpace | IRC | 2 |
Xesxen | Hackalot | IRC | 1 |
Flimpie | via Polyfloyd | Telegram @flippylosaurus | 4 |
Bix | Hack42 | IRC | 4 |
CrazyA | Frack | IRC | 1 |
Dreamer | NurdSpace | IRC | 1 |
Stoneshop | Hack42 | IRC | 1 |
qguv | Revspace | IRC qguv@freenode | 1 |
Gopper | Bitlair | Telegram @robmans | 2 |
XNDR | RevSpace | Phone | 8 |
You? | ? | ? | ? |
Current Total | 47 |
Noodremhandel
- Beschikbaarheid
- Totale aantal: 1329 Afname mogelijk: 740 Frequentie: Per tranche
- Min. afname:50 stuks Locatie: nntb
Sebastius | Revspace | ? | 2 |
Benadski | Revspace | ? | 4 |
Boekenwuurm | Revspace | ? | 2 |
Juerd | Revspace | ? | 1 |
PBX | Revspace | ? | 2 |
Lucanator | Revspace | ? | 1 |
minicom + Niels + Hans + Quint (not qguv) | Revspace | IRC #revspace minicom | 4 |
H3x<tab> | Revspace | ? | 2 |
thomas | Revspace | ? | 2 |
cmpxchg | Revspace | ? | 1 |
Martian | TkkrLab / Hackalot | IRC #tkkrlab martian | 2 |
Muse | TechInc | userpage op techinc wiki | 4 |
polyfloyd | Bitlair | IRC | 2 |
rowan8k | Revspace | IRC | 1 |
eightdot | Bitlair | IRC | 1 |
forseti | Bitlair | IRC #bitlair | 2 |
effractuur | ? | IRC | 10 |
bertrik | Revspace | IRC #revspace | 1 |
jelly | Revspace | IRC #revspace | 1 |
Stoneshop | Hack42 | IRC | 2 |
Dreamer | Nurdspace | IRC | 3 |
Kartoffel | Revspace | IRC #revspace | 1 |
Anus | Revspace | IRC #revspace | 1 |
Katje | TechInc | IRC | 1 |
Renze | Tkkrlab | Telegram @r3nz3 | 2 |
Ultratux | Techinc | IRC | 1 |
Molenaar | Revspace | e-mail/wiki | 2 |
You? | ? | ? | ? |
Current Total | 62 |
Deurbedieningspaneel
minimale afname 50 stuk, bod 10,- p/s
webmind | techinc | irc | 2 |
Wizzup | techinc | irc | 3 |
effractuur | ? | IRC | 2 |
minicom + Niels | RevSpace | irc | 2 |
Wheeze_NL | RevSpace | irc | 2 |
Xesxen | Hackalot | irc | 2 |
Ultratux | Techinc | IRC | 2 |
Boekenwuurm | Hackalot | irc | 1 |
Current Total | 24 |
Treindisplay extern (It's bigger!)
Minimumafname 60 stuks, a 25 euro per stuk (dat is het minimale bod per unit met een beetje marge).
- Beschikbaarheid
- Totale aantal: 348 Afname mogelijk: 200 Frequentie: Per tranche
- Min. afname: 60 stuks Locatie: n.t.b.
- Specificaties
- Lengte: 1002 mm Breedte: 206 mm Diepte: 66,5 mm
- Display: 160,7 x 948 mm
minicom (Niels) | RevSpace | IRC | 1 |
Dreamer | Nurdspace | IRC | 1 |
h3x4d3c1m4l | RevSpace | Telegram @h3x4d3c1m4l | 2 |
Meathur | via f0x | Telegram @Meathur | 1 |
Eightdot | Bitlair | IRC | 2 |
You? | ? | ? | ? |
Current Total | 7 |
