Treinonderdelen
| Project Treinonderdelen | |
| Status | Initializing |
| Contact | Sebastius |
| Last Update | 2019-11-17 |
We kunnen als groep mogelijk treinonderdelen kopen. Alleen interieuronderdelen.
Catalogus
Coordinatie
Inschrijflijst
Treindisplay intern
- Beschikbaarheid
- Totale aantal: 1908 Afname mogelijk: 492 Frequentie: Per tranche
- Min. afname: 100 stuks Locatie: n.t.b.
- Specificaties
- Materiaal: Aluminium, PC, RVS
- Lengte: 707 mm Breedte: 121 mm Diepte:60 mm
| Nickname | Hackerspace | How to contact | Number of units |
| Sebastius | Revspace | IRC #revspace Sebastius | 3 |
| Jolo | Bitlair | TBA (via polyfloyd) | 1 |
| h3x4d3c1m4l | Revspace | Telegram @h3x4d3c1m4l | 2 |
| minicom + Niels | Revspace | IRC #revspace minicom | 2 |
| PBX | Revspace | PBX | 1 |
| Bef0re | Revspace | bef0re | 3 |
| Martian | TkkrLab / Hackalot | IRC #tkkrlab martian | 1 |
| Archels | Hack42 | Archels in #hack42 | 1 |
| Boots | nurdspace | IRC #nurds Boots | 1 |
| thomas | Revspace | IRC #revspace thomastheo | 1 |
| pietdv | Revspace | piet_at_devae.re | 2 |
| rad0 | TechInc | ? | 1 |
| Wizzup | TechInc | ? | 1 |
| eightdot | Bitlair | IRC | 2 |
| Wheeze_NL | RevSpace | IRC | 2 |
| You? | ? | ? | ? |
| Current Total | 24 |
Noodremhandel
- Beschikbaarheid
- Totale aantal: 1329 Afname mogelijk: 740 Frequentie: Per tranche
- Min. afname:50 stuks Locatie: nntb
| Sebastius | Revspace | ? | 2 |
| Benadski | Revspace | ? | 4 |
| Boekenwuurm | Revspace | ? | 2 |
| Juerd | Revspace | ? | 1 |
| PBX | Revspace | ? | 2 |
| Lucanator | Revspace | ? | 1 |
| minicom + Niels + Hans + Quint | Revspace | IRC #revspace minicom | 4 |
| H3x<tab> | Revspace | ? | 2 |
| thomas | Revspace | ? | 2 |
| cmpxchg | Revspace | ? | 1 |
| Martian | TkkrLab / Hackalot | IRC #tkkrlab martian | 2 |
| Muse | TechInc | userpage op techinc wiki | 4 |
| polyfloyd | Bitlair | IRC | 2 |
| rowan8k | Revspace | IRC | 1 |
| eightdot | Bitlair | IRC | 1 |
| forseti | Bitlair | IRC #bitlair | 2 |
| effractuur | ? | IRC | 2 |
| bertrik | Revspace | IRC #revspace | 1 |
| You? | ? | ? | ? |
| Current Total | 35 |
Deurbedieningspaneel
minimale afname 50 stuk, bod 10,- p/s
| webmind | techinc | irc | 1 |
| Wizzup | techinc | irc | 3 |
| minicom + Niels | RevSpace | irc | 2 |
| Wheeze_NL | RevSpace | irc | 2 |
| Current Total | 12 |
Treindisplay extern (It's bigger!)
Minimumafname 60 stuks, a 25 euro per stuk (dat is het minimale bod per unit).
- Beschikbaarheid
- Totale aantal: 348 Afname mogelijk: 200 Frequentie: Per tranche
- Min. afname: 60 stuks Locatie: n.t.b.
- Specificaties
- Lengte: 1002 mm Breedte: 206 mm Diepte: 66,5 mm
- Display: 160,7 x 948 mm
| minicom (Niels) | RevSpace | IRC | 1 |
| You? | ? | ? | ? |
| Current Total | 2 |
