ZX81plus38 simple to build ZX-81 clone
| Project ZX81plus38 | |
| Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% ZX-81 clone that anybody could build, with commonly available parts. | |
| Status | Initializing |
| Contact | mahjongg |
| Last Update | 2019-10-15 |
October 1, 2019 continued
Schematic finished for rev 1.0, updated schematic Bestand:ZX81plus38.pdf, plus preview schematic pictures. Next up, importing the components in the PCB layout, and placement of the parts. No attempts have been made yet to try to support multiple types of ROM/EPROM/FLASH, like the original ZX81 ROM. But this schematic should be complete. New is my attempt to support the canonical cassette loading video bars.
Schematic is now revision 1.1 Bestand:ZX81plus38 rev 1.1.pdf
Revision 1.2: Bestand:ZX81plus38 rev1.2.pdf
