ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% ZX-81 clone that anybody could build, with commonly available parts.
Status Initializing
Contact mahjongg
Last Update 2019-09-29
I had forgotten how much trouble it is to get the connections of the Z80 databus to the NOP enforcer, and pullup resistor pack right, probably I will need lost more wire swapping action to get a somewhat easy to route solution.Laying out this board will be an interactive and iterative process, with lots of forward annotations, and corrections in how everything is connected. I won´t swap data and address lines around for the EPROM (or we have to do some swapping of the EPROM content too, and that is not what I want. This implies that RAM lines swapping won happen either, as the ROM and RAM wiring is almost identical.
here is a preview of the schematic so far. Bestand:ZX81plus38.pdf
