DustSensor
Project Dust Sensor | |
Experiments with a dust sensor | |
Status | Completed |
Contact | bertrik |
Last Update | 2018-04-10 |
To get an idea of the levels of fine dust around my house, I ordered a dust sensor module to play around with. In particular, I ordered this one, the Plantower PMS 7003, AliExpress link. It's being advertised as an advanced generation of dust sensor (7th generation), while still reasonably priced (E15,-). It uses a laser to perform the measurement and it contains a small fan to move the air around.
In parallel with the fine dust level measurement, my device also measures basic meteo data using a BME280 module: temperature, relative humidity and air pressure.
The data produced by this sensor is sent as JSON to a MQTT server. From there it is picked up by two protocol converters: 1) the Telegraf plugin to insert it into my own influx db and 2) a custom written Java application to forward it to the RIVM samenmeten website
Future work
- make temperature, humidity and pressure work with the samenmeten website. This code on github suggests that temperature, pressure, humidity should be submitted as fields "Temp", "Pres", "Hum" respectively (instead of "T", "P" and "RH"!)
- delete old out-of-date data from the samenmeten database, at some point I accidentally submitted some values of 2^31 for some properties (happens when BME280 loses I2C connection): connect to the db using some kind of command-line client
- make it possible to support more than 1 sensor, e.g. also sensors from friends. Like making a distinction between individual sensors using the MQTT topic where the data is published and perhaps keep a table of metadata (with influxdb credentials, sensor location, etc.) at the MQTT listener level
- play with other kinds of sensors, in particular the SDS011, AliExpress link.
Results
Data sheets can be found:
The module takes 5V to run and communicates using 3.3V levels. I connect it using a NodeMCU.
NodeMCU | PMS7003/BME280 | Remark |
D3 | PMS7003-RST | Pulled-up to 3.3V on NodeMCU side, may not be actually needed |
D4 | PMS7003-SET | Pulled-up to 3.3V on NodeMCU side, may not be actually needed |
D5 | BME280-SCL | I2C-SCL |
D6 | BME280-SDA | I2C-SDA, |
D7 | PMS7003-TX | NodeMCU receive, PMS7003 transmit |
D8 | PMS7003-RX | NodeMCU transmit, PMS7003 receive |
GND | PMS7003-GND / BME280-GND | GND ground reference |
VU | PMS7003-VCC | USB voltage (5V) |
3.3V | BME280-VCC |
- experimental (not yet working) arduino software for reading the sds011 dust sensor
- the arduino software reading the pms7003 and sending it as an MQTT stream; and
- a Java based bridge application that takes the MQTT data produced by the arduino and forwards it into the RIVM influx database.
Libraries used:
- SoftwareSerial for serial communication with the sensor
- WiFiClient for WiFi connectivity
- WiFiManager to present a captive portal and allow selection of an AP to connect to the internet
- PubSubClient to handle publishing of data over MQTT
- BME280I2C and wire for interacting with a BME280 for basic meteo data (temperature, humidity, pressure)
Protocol outgoing data
The protocol for measurement data from the module is that data is sent in frames of 32 bytes at 9600 bps. Each frame starts with specific begin marker bytes, then a length byte, then the actual data, and finally a checksum. I use a simple finite state machine to parse the stream and get synchronized to the frames.
Value | Meaning | Remark |
0x42 0x4D | Begin marker | ASCII for characters 'B' and 'M' |
0x00 0x1C | Length | Length of following data |
XX YY | PM1.0 concentration (ug/m3) | CF=1, standard particles |
XX YY | PM2.5 concentration (ug/m3) | CF=1, standard particles |
XX YY | PM10 concentration (ug/m3) | CF=1, standard particles |
XX YY | PM1.0 concentration (ug/m3) | in atmospheric environment |
XX YY | PM2.5 concentration (ug/m3) | in atmospheric environment |
XX YY | PM10 concentration (ug/m3) | in atmospheric environment |
XX YY | Number of particles >0.3 um | in 0.1 liter air |
XX YY | Number of particles >0.5 um | in 0.1 liter air |
XX YY | Number of particles >1.0 um | in 0.1 liter air |
XX YY | Number of particles >2.5 um | in 0.1 liter air |
XX YY | Number of particles >5.0 um | in 0.1 liter air |
XX YY | Number of particles >10 um | in 0.1 liter air |
VV | Version number | ? |
EE | Error code | ? |
C1 C2 | Check code | basically the sum of all bytes up to the check code |
Protocol incoming data
CC | Command | 0xE1, 0xE2 or 0xE4 |
HH LL | Data | Depends on command |
References
Grafana page of my sensor data.
List of dust sensors:
- Dutch RIVM official air quality map
- Dutch RIVM citizen science air quality map
Dust measurement blog:
Making graphs of dust data
Sensor
bertrik/pms7003/json {"pms7003":{"pm1_0":2,"pm2_5":3,"pm10":4},"bme280":{"t":21.1,"rh":50,"p":1012.4}}
Telegraf
Things I did:
- influxdb output plugin
- mqtt_consumer plugin
- data_format="json"
- data_type="integer"
systemctl restart telegraf
Grafana
- SELECT field(amb_pm10)
- GROUP BY
- ALIAS BY PM10
Regelgeving
Regelgeving voor fijn stof (PM10) De regelgeving voor fijn stof (PM10) kent twee doelstellingen: - Een grenswaarde voor het jaargemiddelde: 40 µg/m3 als jaargemiddelde mag niet worden overschreden. Aan deze grenswaarde moet sinds 2005 worden voldaan. Behoudens ‘derogatie’ zijn geen uitzonderingen mogelijk (->Derogatie). Deze grenswaarde beoogt vooral bescherming te bieden tegen de langetermijneffecten van fijn stof. - Een grenswaarde voor het daggemiddelde: 50 µg/m3 als daggemiddelde mag op niet meer dan 35 dagen per jaar worden overschreden. 5 Aan deze grenswaarde moet sinds 2005 worden voldaan. Behoudens ‘derogatie’ zijn geen uitzonderingen mogelijk (->Derogatie). Deze grenswaarde is vooral bedoeld om bescherming te bieden tegen de kortetermijneffecten van fijn stof.
Luftdaten.info
It would be nice to get my data also on the luftdaten.info website and on the lufdaten.info map. Basically I would use the same kind of mechanism as used for RIVM: write a Java program to capture the MQTT stream and convert it to their API.
protocol
Most of the Luftdaten.info upload protocols are described on the luftdaten wiki.
- data is sent as a HTTP POST to https://api.luftdaten.info/v1/push-sensor-data/ (NOTE: the trailing slash!)
- the HTTP POST uses headers "X-Pin" and "X-Sensor" (not case-sensitive it appears)
- header "X-Pin" indicates the type of data
- 1 = SDS011 or PMS7003
- 3 = BMP180
- 5 = PPD42NS
- 7 = DHT22
- 11 = BME280
- header "X-Sensor" indicates the unique sensor id, for example "esp8266-9137604"
- header "Content-Type" with value "application/json" (NOTE: API describes this header, but it's not explicitly sent by the implementations above)
- the body of the POST is JSON with the following fields:
- "software_version": string containing the software version of the sender, for example "python-dusty 0.0.1"
- "sensordatavalues": array of structures containing measurement data, looking like this:
- "value_type" (when X-PIN=1): string describing the measurement item type, can be "P1" (PM10 value) or "P2" (PM2.5 value) with dust value in ug/m3 I suppose
- "value_type" (when X-PIN=7): string describing the measurement item type, can be "temperature", "humidity"
- "value_type" (when X-PIN=11): string describing the measurement item type, can be "temperature", "pressure", "humidity"
- "value": field containing the measurement value (NOTE: in string quotes, not as numeric values!)
As far as I understand, other meta-information like latitude/longitude of the sensor is sent by an e-mail registration process. This is linked to your measurements by means of the unique sensor id.
