Luteijn/Vortex
Project "Vortex":
Project Luteijn/Vortex | |
Contact | Luteijn |
Last Update | 2018-02-01 |
What's connected to the pins
0 | Serial RX (input) |
1 | Serial TX (output) |
2 | Encoder Wheel (External Interrupt 0) (input) |
3 | Encoder Wheel (External Interrupt 1) (input) |
4 | ?? mp3 RX (input) hopefully but don't know. Doesn't seem to be it. Also not head closed sensor (which seems to be straight reed switch for power to top leds) |
5 | Motor 0 Speed (PWM) (outp```ut) |
6 | Motor 1 Speed (PWM) (output) |
7 | IR decoder/detector (input) |
8 | IR led Left (output) |
9 | Motor 0 direction (H=forwards,L=reverse) (output) |
10 | Motor 1 direction (output) |
11 | MP3-player TX (output) |
12 | IR led Right (output) |
13 | GRB LED chain around body (output) |
A0 | grayscale 4 'D' (input) |
A1 | grayscale 3 'C' (input) |
A2 | grayscale 2 'B' (input) |
A3 | grayscale 1 'A' (input) |
A4 | SDA (i2c) |
A5 | SCL (i2c) |
A6 | grayscale 5 'E' (input) |
A7 | grayscale 6 'F' (input) |
i2c bus + Vcc & Vdd should be available at 4 pin rear expansion port too
Motor Control
int E1 = 5; int M1 = 9; int E2 = 6; int M2 = 10; void setup() { pinMode(M1, OUTPUT); // directional controls, High is forward, Low is backward pinMode(M2, OUTPUT); } void loop() { int value; for(value = 0 ; value <= 255; value+=5) //foreward { digitalWrite(M1,HIGH); digitalWrite(M2, HIGH); analogWrite(E1, value); //PWM Speed control analogWrite(E2, value); //PWM Speed Control delay(30); } for(value = 0 ; value <= 255; value+=5) //backward { digitalWrite(M1, LOW); digitalWrite(M2, LOW); analogWrite(E1, value); //PWM Speed control analogWrite(E2, value); //PWM Speed Control delay(30); } }
Encoders
#define pinInputLeft 0 // this is the interrupt, not the pin number, D2 #define pinInputRight 1 // external int 1, D3 long leftPul,rightPul; void leftCallBack(){ leftPul++; } void rightCallBack(){ rightPul++; } void initDdevice(){ pinMode(5,OUTPUT); pinMode(6,OUTPUT); pinMode(9,OUTPUT); pinMode(10,OUTPUT); noInterrupts(); attachInterrupt(pinInputLeft,leftCallBack,CHANGE); attachInterrupt(pinInputRight,rightCallBack,CHANGE); interrupts(); } void motorDebug(){ digitalWrite(5,HIGH); digitalWrite(6,HIGH); digitalWrite(9,HIGH); digitalWrite(10,HIGH); } void printPul(){ Serial.print(leftPul); Serial.print(" "); Serial.println(rightPul); leftPul = 0; rightPul = 0; } void setup() { initDdevice(); Serial.begin(9600); motorDebug(); } void loop() { printPul(); delay(500); }
Analogue Inputs
2 (a2) 3 (a1) 1 (a3) 4 (a0) 5 (a6) 6 (a7)
void setup(void){ Serial.begin(9600); } int analogBuf[6] = {'\0'}; void loop(void){ analogBuf[0] = analogRead(3); analogBuf[1] = analogRead(2); analogBuf[2] = analogRead(1); analogBuf[3] = analogRead(0); analogBuf[4] = analogRead(6); analogBuf[5] = analogRead(7); for(int i=0;i<6;i++){ Serial.print(i+1); Serial.print(": "); Serial.print(analogBuf[i]); Serial.print(" "); } Serial.println(); delay(500); }
LEDs
FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, NUM_LEDS);
IR obstacle detector
Seems to be somewhat flaky. Needs a bit more work to figure out. Also, the IR sensor might be useful to read IR remote controllers or beacons. This receiver seems to work at 38kHz, but probabbly also reacts to 36-40kHz. Remote controllers often work at 36kHz. Note that 2x 8µs delay doesn't give you 38kHz, but the digitalWrite itself also induces quite some delay (3-6µs), so seems this is bringing the total period up to around the 26.something µs we'd expect.
#define NUM_LEDS 12 // Data pin that led data will be written out over #define DATA_PIN 13 CRGB leds[NUM_LEDS]; #define IR_IN 7//IR receiver pin #define L_IR 8 //left ir transmitter pin #define R_IR 12 //right ir transmitter pin int count; void leftSend38KHZ(void){//left ir transmitter sends 38kHZ pulse int i; for(i=0;i<24;i++){ digitalWrite(L_IR,LOW); delayMicroseconds(8); digitalWrite(L_IR,HIGH); delayMicroseconds(8); } } void rightSend38KHZ(void){//right ir transmitter sends 38kHZ pulse int i; for(i=0;i<24;i++){ digitalWrite(R_IR,LOW); delayMicroseconds(8); digitalWrite(R_IR,HIGH); delayMicroseconds(8); } } void pcint0Init(void){//init the interrupt PCICR |= 1 << PCIE2; PCMSK2 |= 1 << PCINT23; //pin D7 is int23 } ISR(PCINT2_vect){//IR decoder interrupt count++; } void obstacleAvoidance(void){ char i; count=0; leds[5] = CRGB::Green; FastLED.show(); for(i=0;i<20;i++){ //left transmitter sends 20 pulses leftSend38KHZ(); delayMicroseconds(600); } if(count>10){//if received a lot pulse , it means there's a obstacle leds[5] = CRGB::White; FastLED.show(); Serial.println("Left"); delay(100); } count=0; leds[3] = CRGB::Green; FastLED.show(); for(i=0;i<20;i++){//right transmitter sends 20 pulses rightSend38KHZ(); delayMicroseconds(600); } if(count>10){//if received a lot pulse , it means there's a obstacle leds[3] = CRGB::White; FastLED.show(); Serial.println("Right"); delay(100); } delay(600); } void setup(void){ delay(2000); FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, NUM_LEDS); pinMode(L_IR,OUTPUT);//init the left transmitter pin pinMode(R_IR,OUTPUT);//init the right transmitter pin pinMode(IR_IN,INPUT);//init the ir receiver pin Serial.begin(9600); leds[4] = CRGB::Blue; FastLED.show(); delay(2000); leds[4] = CRGB::Purple; FastLED.show(); noInterrupts(); pcint0Init(); interrupts(); //enable the interrupt } void loop(void){ obstacleAvoidance(); }
IRreceiver
#include "IRremote.h" #define IR_IN 7//IR receiver pin IRrecv irrecv(IR_IN); decode_results results; void setup(void){ Serial.begin(9600); irrecv.enableIRIn(); // Start the receiver } void loop(void){ if (irrecv.decode(&results)) { Serial.println(results.value, HEX); irrecv.resume(); // Receive the next value } }
MP3-player
#define MP3_VOLUME 0x10 #define TX 11 #define RX 4 // ?? was 2 in example I found, but that is unlikely #include <SoftwareSerial.h> SoftwareSerial mySerial(RX, TX);// RX, TX void setup() { delay(1000); mp3Init(); mp3setVolume(30);//0~255 } void loop() { mp3player(1); delay(2000); mp3stop(); delay(1000); } void mp3Init() { mySerial.begin (9600); } void mp3setVolume(byte vol) { uint8_t buffer[] = {0x7e, 0xff, 0x06, 0x06, 0x00, 0x00, vol, 0xef}; mySerial.write(buffer, 8); delay(20); } void mp3player(byte data) { uint8_t buffer[] = {0x7e, 0xff, 0x06, 0x03, 0x00, 0x00, data, 0xef}; mySerial.write(buffer, 8); delay(20); } void mp3stop() { uint8_t buffer[] = {0x7e, 0xff, 0x06, 0x16, 0x00, 0x00, 0x00, 0xef}; mySerial.write(buffer, 8); }
https://www.dfrobot.com/product-1121.html , documented at https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299 is a mini-MP3 player from DFRobot. It is controllable over serial, and might be the same one as used in the Vortex. Would be good to figure out if the 'busy' signal and/or the serial TX are connected back to the arduino somewhere in that case. Player could also be a variant but the magic numbers more or less match (although the stop command 0x16 is not in the table. Perhaps Dec16 / 0x0A (standby/low power mode) was meant? The MP3-chip Part# is YX6100-24SS. Seems to be part of a family of serial MP3-players.
$S | Start byte 0x7e | Each command begins with 0x7e ('~') |
VER | Version information | Version seems to be 0xff from the example |
Len | the number of bytes | Start, End and Checksum are not counted, |
CMD | Commands | See command table. |
Feedback | Command feedback | 1: feedback, 0: no feedback ; need to test what this does, might mean 'echo' |
Para1 | Parameter 1 | Query high data byte |
Para2 | Parameter 2 | Query low data byte |
checksum | Checksum | accumulation and verification, doesn't include start byte. Seems to be 2 bytes from the example given in the docs, but Vortex seems to just not need it put in. example given is 7e ff 06 09 00 00 04 ff dd ef |
$O | End byte | End of command is signaled with 0xEF |
uint16_t DFRobotDFPlayerMini::calculateCheckSum(uint8_t *buffer){ uint16_t sum = 0; for (int i=Stack_Version; i<Stack_CheckSum; i++) { sum += buffer[i]; } return -sum; }
Eyes
Besides 35 predefined eye patterns, it is also possible to upload your own eye patterns.
#include <Wire.h> #define I2C_LED_ADDRESS 0b1100000 #define I2C_WRITE 0x00 uint8_t serial=0; void setup(){ Wire.begin(); // join i2c bus (address optional for master) defined_eyes(6,1); delay(2000); } void loop(){ defined_eyes(1,serial); serial++; if(serial>=35) serial=0; delay(250); } void defined_eyes(uint8_t color,uint8_t serial) { Wire.beginTransmission(I2C_LED_ADDRESS << 1 | I2C_WRITE); // transmit to device #4 Wire.write(color&0x07); // color bits: 1 blue, 2 green, 4 red Wire.write(serial); //preset eyes 0~34 Wire.endTransmission(); // stop transmitting }
void custom_eyes(uint8_t color, uint8_t eyeline[10]){ uint8_t index; // right eye left eye //1 2 3 4 5 25 24 23 22 21 //6 7 8 9 10 20 19 18 17 16 //11 12 13 14 15 15 14 13 12 11 //16 17 18 19 20 10 9 8 7 6 //21 22 23 24 25 5 4 3 2 1 Wire.beginTransmission(I2C_LED_ADDRESS << 1 | I2C_WRITE); // transmit to device #4 Wire.write(0x55); // color 55=custom eyes follow Wire.write(0xAA); // ?? AA=color followed by 10 bytes, each defining one line // other values cause eyes to light up in multiple colors, needs more work Wire.write(color&0x7); //color 1-B,2-G,4-R of foreground for (index=0;index<10;index++) { Wire.write(eyeline[index]); } Wire.endTransmission(); // stop transmitting void example_eyes() { /* left eye of robot (right for onlooker) */ Wire.write(0x1f); // bottom row, all bits lit Wire.write(0x1e); // 10 9 8 7 on, 6 off Wire.write(0x1c); Wire.write(0x18); Wire.write(0x10); /* right eye of robot (left for onlooker) */ Wire.write(0x1f); // top row all 5 bits lit Wire.write(0x0f); // leds 6,7,8,9 on 10 off Wire.write(0x07); // 11,12,13 on, 14,15 off Wire.write(0x03); Wire.write(0x01); }
