DustSensor
Revision as of 12:52, 24 December 2017 by Bertrik Sikken (talk | contribs)
Project Dust Sensor
Last Update 2017-12-24
I ordered a dust sensor module to perform measurements of airborne dust. In particular, I ordered this one, the Plantower PMS 7003, AliExpress link. It's being advertised as an advanced generation of dust sensor (7th generation), while still reasonably priced (E15,-). It uses lasers to perform the measurement and I think it contains a small fan to move the air around.
Graph
Data sheets can be found:
The module takes 5V to run and communicates using 3.3V levels.
It makes an estimate of the number of particles per size category, total 6 categories: 0.3-0.5-1.0-2.5-5.0-10 micrometer. It also gives an estimate of the total mass of the particles in 3 categories: PM1.0, PM2.5 and PM10. I don't know how it actually works on the inside and is able to make a distinction between particles of different size.
The software archive can be found at github. Reading measurements works, sending commands to the module does not. I don't know yet whether this is a hardware or software problem.
Libraries used:
  • SoftwareSerial for serial communication with the sensor
  • WiFiClient for WiFi connectivity
  • WiFiManager to present a captive portal and allow selection of an AP to connect to the internet
  • PubSubClient to handle publishing of data over MQTT
This dust sensor outputs its data as a 32-byte serial data stream at 9600 bps.
Protocol outgoing data
The protocol for measurement data from the module is that data is sent in frames. Each frame starts with specific begin marker bytes, then a length byte, then the actual data, and finally a checksum. I think it is a good match to use a simple finite state machine to parse the stream and get synchronized to the frames.
Protocol
Value Meaning Remark
0x42 0x4D Begin marker ASCII for characters 'B' and 'M'
0x00 0x1C Length Length of following data
XX YY PM1.0 concentration (ug/m3) CF=1, standard particles
XX YY PM2.5 concentration (ug/m3) CF=1, standard particles
XX YY PM10 concentration (ug/m3) CF=1, standard particles
XX YY PM1.0 concentration (ug/m3) in atmospheric environment
XX YY PM2.5 concentration (ug/m3) in atmospheric environment
XX YY PM10 concentration (ug/m3) in atmospheric environment
XX YY Number of particles >0.3 um in 0.1 liter air
XX YY Number of particles >0.5 um in 0.1 liter air
XX YY Number of particles >1.0 um in 0.1 liter air
XX YY Number of particles >2.5 um in 0.1 liter air
XX YY Number of particles >5.0 um in 0.1 liter air
XX YY Number of particles >10 um in 0.1 liter air
VV Version number ?
EE Error code ?
C1 C2 Check code basically the sum of all bytes up to the check code
Protocol incoming data
Command Protocol
CC Command 0xE1, 0xE2 or 0xE4
HH LL Data Depends on command
References
List of dust sensors:
Citizen science projects for measuring ultra fine dust:
Dust measurement blog:
Making graphs of dust data
  • graphana, to grab the data from the database and display it
Sensor
An important thing to consider, is to omit the any unit from the measurement values in MQTT, so the published value can be parsed as an integer/float. So, use '10' instead of '10 ug/m3', for example.
Telegraf
Things I did:
    • influxdb output plugin
    • mqtt_consumer plugin
      • topics=[ "bertrik/pms/#" ] (REALLY?)
      • data_format="value"
      • data_type="integer"
  systemctl restart telegraf
Grafana
  • FROM mqtt_consumer WHERE topic = bertrik/pms7003/PM10
  • SELECT field(value)
  • GROUP BY
  • ALIAS BY PM10
  • repeat for other particle sizes (PM1.0 and PM2.5)
