Lasercutter1
| Project Lasercutter | |
| Status | Working"Working" is not in the list (Proposed, Initializing, In progress, Completed, Stalled, Abandoned) of allowed values for the "Project Status" property. |
| Contact | Walter, FooBar, GMC |
| Last Update | 2012-01-16 |
Lasercutter Checklist
- Fans are turned on
- The Laser-tube is filled with water, no bubbles are visible in the stream
- The water-pump is running without bubbles
- The water is cool
- The Z-axis is set correctly for your material
- The laser output power is set correctly for your material
Then, when making a print/cut
- Do a test-run first, with the laser power disabled, to see if your design works without errors or hitting the borders
- Position your material efficiently
- Keep the fire extinguisher nearby
- Always remain at the lasercutter when it is active
- Hit the emergency/stop button when something goes wrong
