Photomultipliers
Project Photomultipliers
Status Initializing
Contact thomas
Last Update 2017-03-17
Background
For those unfamiliar with photomultipliers, they are vacuum tube devices used for detecting and quantifying incredibly tiny amounts of light, even single photons. They make use of the photoelectric effect to 'convert' photons to electrons, and subsequently amplify the resulting signal by employing a high potential difference and a cascade of what are called dynodes. The first incident photon liberates a single electron at the photocathode window, which is then accelerated into the first dynode by the potential difference, kicking off a number of electrons that then accelerate to the next dynode, kicking off even more electrons, and so on. After this process repeats half a dozen to a dozen times, that one photon/electron event will have been amplified with enormous gain, up to six orders of magnitude or more, resulting in a signal that can easily be measured and recorded.
I came across a small lot of old photomultiplier tubes on a Dutch on-line auction site. Besides the usual experiments involving detection of various kinds of ionizing radiation, I’d like to use them to have a look at the properties of some inexpensive and readily available materials that could perhaps be used as a scintillator instead of the specialized, optimized and expensive scintillators employed in professional instruments. I’ll use this page to document my progress in putting together a suitable high voltage bias supply and voltage divider, as well as a simple peak detector/amplifier, and eventually (hopefully) describe some simple experiments.
Specifications
The tubes I bought are chunky 2’’ units, with a bialkali photocathode composition that has a spectral sensitivity specifically designed to correspond well with the emissions of traditional scintillator materials, used in the detection of ionizing radiation. They seem to be quite high-end, tailored specifically for research applications, so I imagine they will be quite suitable for what I intend to do with them. I have four to play with.
Type: XP2202B
Dynodes: 10
Window diameter: 52mm
Old photomultipliers
As you can see, these tubes are not exactly new, and have apparently been sitting in a dusty university cupboard for over thirty years. Given their age, my first impulse was to do some research into whether there was still a chance of getting some useful life out of them after all this time. Luckily it seems that PMTs are generally quite reliable devices. As long as you shield them from excessive light exposure when powered, run them within their specification on a suitable regulated power supply, and avoid undue mechanical/thermal stress on the pins and glass envelope, their service life will end up being equal to their shelf life. As far as I’ve been able to gather, the most important factor determining shelf life is the kind of glass used in constructing the envelope. UV-sensitive tubes require an end window made of fused quartz, because conventional glass attenuates light of shorter wavelengths. Tubes used in applications involving thermal shock are generally fashioned from borosilicate glass. If these design constraints are not of significant concern, tubes are usually made with plain old soda lime glass.
So why is this relevant? Surprisingly (to me anyway) it turns out that shelf life is directly related to the ingress of helium gas into the tube. On account of it being tiny and mono-atomic, helium gas will diffuse through the glass envelope, causing the pressure inside to slowly rise until it equals the partial pressure of helium in the air outside. Given normal environmental conditions this partial pressure is quite small (5x10^-6 atmospheres), but it’s nevertheless enough to interfere with proper functioning, leading to undesirable behavior such as after-pulses, or even complete failure of the tube. As it happens, quartz glass is relatively permeable to helium, and so quartz PMTs just don’t have a shelf life that extends much past a decade. After quartz, pyrex/borosilicate are the next most permeable envelope materials, and the least permeable of all is soda lime glass, which happens to be the material used in the construction of the XP2202b. From what I can gather, helium ingress is a very slow process even with borosilicates, and profoundly more so in the case of lime glass, so I have good hope that these tubes are still perfectly usable, with much of their functional life remaining. The actual shelf life you get comes down to the concentration of helium in the storage environment (up to a point anyway, obviously other mechanisms of degradation will eventually start to overtake this particular failure mode) and while I don’t know what kind of cupboard they were kept in, I don’t imagine it was directly next to a hissing dewar of liquid helium. Apparently even a few hours in an atmosphere of pure helium is enough to ruin a quartz tube. I choose to be optimistic and assume that they were stored on a shelf next to the rubiks cubes and spare pocket protectors.
Plans
To-do list:
Everything, really.
Dynode divider
Peak detector/digitizer
Scintillators
Ebay is a great source for relatively inexpensive surplus scintillators of all types. Old soviet doped sodium iodide crystals, modern plastic scintillators, LYSO scintillators, they’re all available. So far I have not been able to find affordable large volume/ surface area scintillators, such as the ‘paddles’ conventionally used for things like muon detectors. This project is meant to be fun, so I’m just not willing to spend piles of money on slabs of plastic. Besides, I think it would instead be fun to try and make a detector with a scintillator comprised of more affordable and readily available materials. It certainly doesn’t have to be highly optimized or competitive to be adequate for my purposes.
The first ever scintillator, in use long before the invention of the photomultiplier tube, was silver-activated zinc sulfate. Applied as a thin coating on a screen or membrane, it was used in things like spintharoscopes, fluoroscopes and x-ray photo-cassettes. It’s also responsible for the actual glow emitted by radio-luminescent radium paint (albeit doped with copper, which gives a longer lasting green emission). ZnS screens are inexpensive and available, but due to this compound being quite opaque, they are not useful for constructing high volume detectors. They’re great as alpha probes though, so I will definitely give this a go.
Some other early scintillators were made with various aromatic hydrocarbons, traditionally anthracene, stilbene, and naphthalene. Whereas you won’t find the first two at the corner drugstore, naphthalene is quite commonly available in the form of moth balls. Besides the horrendous smell, there are a number of other downsides, unfortunately. Due to the response of these materials being anisotropic (the amount of light produced by scintillation varies with the angle of incidence of the ionizing radiation) it is not possible to use them in applications where you are looking to determine the relative energy of any particles you’re detecting (unless the incident radiation is in the form of a collimated beam, but since I don’t have a particle accelerator, this is not likely to be relevant to my use case). It’s also quite difficult to grow large transparent crystals from these compounds, which is of course necessary if you want to make practical large volume detectors. One way of getting around that problem is to use a suitable solvent, preferably one that has its own scintillation properties, to make a liquid scintillator.
Liquid scintillators are widely used in physics experiments these days, with a vast range of liquid cocktails available commercially. I’m not willing to use expensive specifically purified isomers most suitable for scintillation, or particularly nasty solvents such as benzene, so the possible options are quickly whittled down to only a few contenders. The most likely among them is xylene, which is reasonably inexpensive, not excessively hazardous, and happens to be quite suitable in combination with naphthalene.
Updates
This page is a work in progress, and will be updated if and when I have something to report on.
