Lastcall
Versie door Qguv (overleg | bijdragen) op 2 okt 2015 om 01:30 (no it doesn't)
Project lastcall
Contact User:qguv
Last Update 2015-10-02
Tells you your last chance to get home via public transit. Currently a small website giving leaving/arrival time estimates from Google Maps Directions API, but will soon have a (much) nicer web interface (automatic updating/cycling and so).
~200 lines of Python running in a Docker container, see the Github and Docker pages. Probably should've used Haskell, but the Python library bindings were somewhat nicer (i.e. don't require globbing together URLs and parsing JSON).
Environment and Hardware
lastcall runs as a web service on shell.space.revspace.nl. It is controlled with systemd. Once it's been built (from the development directory), the image is available on the local machine for anyone to use.
ssh shell.space.revspace.nl
sudo systemctl start/stop/enable/disable lastcall
