3d-printer-compare
Versie door Semafoor (overleg | bijdragen) op 17 feb 2015 om 09:04 ('t is de verkorte 'past simple'. €1999 when the machine is built for us (in the factory). Also fixed the table)
3D printer vergelijking
Onze eisen
Parameter Value
Aanschafwaarde € ?
Minimum Maximum print dimensions ? x ? x ? mm
Usable materials ABS, PLA, ?
Surface roughness / print accuracy* better than 0.5 mm (at least!)
Mogelijke printers
Besproken op de MetaMeeting14x05x13.
Mankati Fullscale XT Cartesio W1CE Lulzbot TAZ 4 Ultimaker II Deltamaker Renkforce RF1000 PP3DP 3D printer Up! Mini
Prijs €2150 €3600 €2195 €2300 incl. BTW $2400 €1999 (built)
€1599 (kit)
€639 (built)
PLA YES X YES YES YES YES X
ABS YES X YES YES ? YES YES
PVA YES X YES ? ? ? X
Other materials nylon, Laywood, Laybrick & Ninjaflex nylon, Laywood, Laybrick & Ninjaflex Laywood, PET, , Polyamid (nylon)
Filament reel price (weight) €38 - 42 (0.75 kg) $39 (1 kg) €45 (2.1 kg) €39 (0.7 kg)
Filament Diameter 3 mm 3 mm 3 mm 2.85 mm 1.75 mm 1.75 mm
Filament Temp 150 tot 250 °C x max 240 °C 180 - 260 °C x
File support stl, obj, gcode x STL / OBJ / DAE / AMF STL
Print speed -180 mm/s -150 mm/s -200 mm/s 30-300 mm/s 9min per cm3
Accuracy* X,Y axis 0.0125 mm, Z axis 0.001 mm 0,28 mm 0,1 mm 0.0125 mm (X,Y), 0.005 mm (Z)
Stepper Motor* X, Y 4248, 1.3A, Z 4263, 1.5A x x x x x
Controller* Arduino Mega 2560 R3 x open source YES
Linux YES x YES YES Yes
Software MankatiUM (Based on Cura) x x Cura Marlin, OctoPrint, Repetier Host, and Slic3r Linux drivers (FWIW)
Extruders max 2 max 4 max 1 1 1 1
Max. print dimensions 250×250×300 mm 400x200x200 mm 297x274x248 mm 230x225x205 mm 254Øx278 mm 250x235x175 mm 120x120x120 mm
Extrude Nozzle 0,4 mm (0,3 en 0,5 beschikbaar) ? 0.075mm to 0.35mm 0.4 mm 0.5 mm 0.2 mm - 0.35 mm
Hot bed YES x YES 50-100 °C YES, changeable YES 50 °C
Bed materiaal Monocrystal glass x Borosilicate glass bed covered with PET film glass Ceramic
Closed printing area Ja Ja Nee closed sides, open front/top No, completely open No, open back and front YES
External dimensions (wxdxh) 380x420x530 mm x 680x520x515 mm 492x342x558 mm (incl. filament) 375x410x500 mm 245x260x250 mm
Weight* 25 kg x 11 kg YES 16.5 kg 5 kg
Notes Mankati is via Rix Graveert ook, "zit in maasstricht" Open source hardware & software, Open source hardware & software, Waarschijnlijk beter om een opgebouwde versie te kopen (garantie etc)
Dikte druklaag (min.): 0.05 mm Dikte druklaag (max.): 0.4 mm Interfaces: USB 2.0 Kleur: Zilver (gesatineerd) Stroomverbruik (max.): 620 W Materiaal behuizing: Aluminium, staal SD-slot
Hugely tiny print area
Link http://www.mankati.com/fullscale-xt.html http://mauk.cc/webshop/systems/cartesio-assembled/Cartesio-w1ce-assembled https://www.lulzbot.com/products/lulzbot-taz-4-3d-printer https://www.ultimaker.com/pages/our-printers/ultimaker-2 http://www.deltamaker.com/ https://www.conrad.nl/nl/renkforce-rf1000-3d-printer-1007508.html http://www.bcc.nl/computer/printer-en-scanner/3d-printer/pp3dp-3d-printer-up--mini(76151)
x = niet bekend
* = unreliable or irrelevant specification
