Gebruiker:Bertrik Sikken
Versie door Bertrik Sikken (overleg | bijdragen) op 15 sep 2014 om 09:28 (Add e-mail address)
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
  • software-defined radio
Old project ideas:
  • do cool stuff with NRF24L01+ modules, e.g. connect one to the SPI bus of a Raspberry Pi
  • experiment with MQTT, a light-weight publish/subscribe framework for telemetry data
  • put the things above together in some kind of home automation project
  • build a colinear antenna out of RG-6 coaxial cable for the 70cm band (for receiving high-altitude balloons)
  • more radio stuff with the ham-it-up
  • implement dominoex/thor radio mode for a balloon payload, perhaps build a light-weight reusable library
  • come up with an algorithm to determine position/direction of bats as they pass a set of ultrasonic microphones, see StereoBatRecorder
    • I've tried direct correlation, works but sometimes gives errors on bat calls with little frequency sweep
    • Planning to try correlation of only the amplitude data (derived with a Hilbert transform)
New project ideas:
  • Use two old satellite dishes to allow speech to be transferred over some distance
    • Figure out focal point
    • Create some kind of dish mount
  • Reverse engineer the digital oscilloscope at revspace
    • Figure out screenshot image format
    • Try to find if there are other commands than the "send screenshot" command
  • More LedBanner audio visualisations
  • Create a RFM69HW TNC, based on code by flok
    • Remove 'flok' framing, make it comply with KISS protocol
    • Use 'infinite' package length mode to send typical TCP/IP frames (1500 bytes)
  • Create a 'HabAlert' android app, see HabAlertApp
  • add opus audio codec support to squeezeboxserver and/or squeezelite
    • an opus web radio stream already seems to be redirected to the client, but squeezelite crashes on it
  • create code for remote control of my ZwaaiLicht
    • implement wireless protocol for the NOMZ message ("\x4NOMZ") on address 0x66996699L (no ack)
    • possibly implement a more capable protocol on a different pipe (with ack, learn about extra pipes on NRF24L01+)
    • possibly split control of the light and the motor
  • create a voordeur display
    • clearly indicates the RevSpace door bell
    • show short scrolling text messages, e.g. to food delivery people
    • remote control over NRF24, e.g. enable/display the display of messages, set the text to be displayed
