3d-printer-compare
3D printer vergelijking
Onze eisen
Parameter Value
Aanschafwaarde € ?
Minimum Maximum print dimensions ? x ? x ? mm
Usable materials ABS, PLA, ?
Surface roughness / print accuracy* better than 0.5 mm (at least!)
Mogelijke printers
Besproken op de MetaMeeting14x05x13. Eerste model (Mankati) is via Rix, tweede model (Carteso) zit in maasstricht en Lulzbot onbekend.
Mankati Fullscale XT Cartesio W1CE Lulzbot TAZ 4 Ultimaker II Deltamaker
Price 2150 3600 2195 € 2300 incl. BTW $ 2400
PLA YES x YES YES YES
ABS YES x YES YES ?
PVA YES x YES ? ?
Filament reel price (weight) € 38 - 42 (0.75 kg) $ 39 (1 kg)
Filament Diameter 3 mm 3 mm 3 mm 2.85 mm 1.75 mm
Filament Temp 150 tot 250 °C x max 240 °C 180 - 260 °C
File support stl, obj, gcode x STL / OBJ / DAE / AMF
Print speed -180 mm/s -150 mm/s -200 mm/s 30-300 mm/s
Accuracy* X,Y axis 0.0125 mm, Z axis 0.001 mm 0,28 mm 0,1 mm 0.0125 mm (X,Y), 0.005 mm (Z)
Stepper Motor* X, Y 4248, 1.3A, Z 4263, 1.5A x x x
Controller* Arduino Mega 2560 R3 x open source YES
Linux YES x YES YES
Software MankatiUM (Based on Cura) x x Cura Marlin, OctoPrint, Repetier Host, and Slic3r
Extruders max 2 max 4 max 1 1
Max. print dimensions 250×250×300 mm 400x200x200 mm 297x274x248 mm 230x225x205 mm 254Øx278mm
Extrude Nozzle 0,4 mm (0,3 en 0,5 beschikbaar) ? 0.075mm to 0.35mm 0.4 mm
Hot bed YES x YES 50-100 °C
Bed materiaal Monocrystal glass x Borosilicate glass bed covered with PET film glass
Closed printing area Ja Ja Nee closed sides, open front/top No, completely open
External dimensions 380x420x530 mm x 680x520x515 mm 492x342x558 mm (incl. filament)
Weight* 25kg x 11kg YES
Notes x Graveert ook Open source hardware & software, print ook nylon, Laywood, Laybrick & Ninjaflex Open source hardware & software, print ook nylon, Laywood, Laybrick & Ninjaflex
Link http://www.mankati.com/fullscale-xt.html http://mauk.cc/webshop/systems/cartesio-assembled/Cartesio-w1ce-assembled https://www.lulzbot.com/products/lulzbot-taz-4-3d-printer https://www.ultimaker.com/pages/our-printers/ultimaker-2 http://www.deltamaker.com/
x = niet bekend
* = unreliable or irrelevant specification
