Spectrum polish off
Versie door Mahjongg (overleg | bijdragen) op 19 apr 2014 om 23:03 (more mods I forgot to mention)
Project Spectrum polish off
Contact mahjongg
Last Update 2014-04-19
Sinclair Spectrum polish off is a project to restore a donated defective Sinclair spectrum to working order, and to add some additional features:
Fixes done until now:
  • Replaced blown up 7805 voltage regulator.
  • Repaired the +12V & -5V generator (replaced two transistors).
  • Completely replaced foil keyboard by 40 6x6mm buttons, hot glued to the inside and hard wired, the rubber keypad was modified to make place for the buttons.
  • Built in a 1 transistor preamp to make the cassette input sensitive enough so it accepts signals from a tablet or laptop.
replaced a rubber feet
added a composite video output cable
TODO:
Add a built in joystick port, that works by activating certain keys, by using FET's connected between the keyboard matrix points for the keys, 5,6,7 & 8, and 0 for fire.
