Meshtastic
Project Meshtastic
Experiments with Meshtastic
Last Update 2025-03-09
Intro
The plan is to use Meshtastic to transfer citizen science measurement data.
Stuff to figure out:
  • network coverage: meshnet.nl map
  • do nodes forward packets that do not belong to their "own" network? -> appears to be so!
My node: https://db.meshnet.nl/da639b54.html
Design
Option 1
plans:
  • just use the 'default' channel: longfast + default key
  • put my data on an unused port number, e.g. 300
pro&con:
  • + simple
  • + my data is routed
  • - there are only 256 (or so) port numbers globally, so cannot really differentiate
  • could combat this with a kind of secure checksum
Option 2
plans:
  • use my own channel: probably 'longfast' + own key
  • use a port number > 256
pro&con:
  • + data is separate from other data
  • + data *should* be routed (not 100% sure)
  • - have to do my own decryption
Protocol
Quick links:
MQTT
In the netherlands, data is typically sent to the 'boreft' MQTT server, for example
Examples of typical data:
 msh/7460-7463/2/stat/!da5857c0 online
 msh/EU_868/NL/2/e/LongFast/!eb66115c �%]�g(=���gx�� H5��Aw=]�gE��H`���������LongFast␦
Example data
Examples of data as decoded from MQTT using the meshtastic python service wrapper:
packet {
  to: 4294967295
  decoded {
    portnum: POSITION_APP
  rx_time: 1741511999
  rx_snr: -18
  hop_limit: 2
  rx_rssi: -128
  hop_start: 3
channel_id: "LongFast"
gateway_id: "!da544e50"
Packet with encrypted data:
packet {
  to: 4294967295
  channel: 8
  rx_time: 1741512321
  rx_snr: 5.75
  hop_limit: 4
  rx_rssi: -83
  hop_start: 5
gateway_id: "!da5c87d4"
packet {
  to: 4294967295
  channel: 8
  encrypted: "t\235\250XV\314\256\211\222\253~\245"\357z\252\314U<VZn\210\031\272\230.5\322\345\272\035\212?f\214"
  rx_time: 1741514045
  hop_limit: 3
  priority: BACKGROUND
  hop_start: 3
  relay_node: 161
gateway_id: "!ac774aa1"
