Karaburan
| Project Karaburan | |
| Monitoring water quality | |
| Status | Initializing |
| Last Update | 2024-06-16 |
- write python scripts
- gpsd-to-mqtt
- arduino turbidity
- turbidity-to-mqtt
- hook things into systemd
- analoog in op de pi:
- 1-wire stuff:
Topics:
- air quality sensors
- ammonia
- NOx
- water chemical analysis
- nitrates
- ammonia
- dissolved oxygen
- sulfide/sulfate
- phosphates?
- salinity (chlorides?)
- water physical analysis
- temperature
- depth?
- boat control
- trajectory -> steering
- camera control
- post-processing
- data presentation
- video/photo stitching
- time lapse view
- map view of properties
- data presentation
- use cases
- minimum viable prototype
- materials
- boat selection
Air quality sensors
Nitrogen compounds in air
- NOx: 27.3 ug/m3
- NO2: 18.6 ug/m3 (9.9 ppb)
Water physical analysis
Turbidity / clarity
Boat control
- 2.4 GHz working frequency
- 500m range
Interesting links:
remote control
Parts:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
Detect/find pollution source
Implementation
reading temperature sensor
Preparation:
sudo adduser <name> dialout
Setting up the hardware:
Setting up the software:
- Install openwire fs
sudo apt install owfs
sudo mkdir /mnt/1wire
- Configure systemd services
- Start the systemd service
- Check the logs
