HAB Tracker Station
Revision as of 22:19, 24 December 2012 by Maxell (talk | contribs) (Software)
Project pagina voor het high altitude balloon tracking/listening station dat we voor de space aan het inrichten zijn.
Done
Acquired Hardware
  • "ezcap USB 2.0 DVB-T/DAB/FM" dongle, RTL2838U, Fitipower FC0013 tuner, Supported gain values (23): -9.9 -7.3 -6.5 -6.3 -6.0 -5.8 -5.4 5.8 6.1 6.3 6.5 6.7 6.8 7.0 7.1 17.9 18.1 18.2 18.4 18.6 18.8 19.1 19.7
  • VK5QI HABamp
  • Raspberry Pi
  • Test payload, RFM22b sending RTTY strings on 434.250MHz. Code here: https://github.com/costyn/rfmtest/blob/master/rfmtest.pde
  • Sending test payload --> works!
  • Sending data from rtl_tcp on RasPi over the network --> works! (1024000 samples/second seems to go fine when both are on a wired connection)
  • gqrx to listen to audio --> works!
  • dl-fldigi RTTY decoding --> works!
  • Testing VNC performance with gqrx and dl-fldigi --> usable with JPEG compression and 8 bits of color
Todo
  • Setting up a virtual machine with gqrx and dl-fldigi
revspace@habraspi:~$ rtl_tcp -a 10.42.43.20
Found 1 device(s). Found Fitipower FC0013 tuner
Using ezcap USB 2.0 DVB-T/DAB/FM dongle
Todo
  • Site survey roof, check if there is already some sort of lightning protection system, and see if we can add some metal construction to it ourselfs
  • Currently we have no antenna. Well need some heavy duty (directional?) antenna.
    • Do we make one or do we buy one?
    • What kind of antenna? (keep in mind we only have line of sight towards south/southwest)
  • Enclosure spec-en en aanschaffen
  • Routing 230v and Ethernet towards the roof
  • Your ideas, we love them!
