LoRa-E5-mini
Project LoRa E5
Arduino on the LoRa-E5-mini devboard
Last Update 2021-10-18
The plan
  • replace the original "AT" firmware with Arduino based firmware
  • use the BasicMac library for LoRaWAN
  • use platformio as the build system
  • create some basic examples for use as a LoRaWAN node on TheThingsNetwork
What currently works:
  • can run an Arduino program, compiling from the Arduino IDE
  • blinking the LED works
  • output over serial works
TODO, yet to figure out:
  • add support for the Seeed LoRa E5 mini in the stm32 package
  • get communication going using the internal "subghz" SPI port
    • do I need to enable the APB3 clock domain?
    • get a simple transfer going that proves that meaningful data is exchanged (e.g. default sync word magic number)
  • get basicmac stack working with the "subghz" SPI port (it appears all communication is done using just "SPI")
  • get compilation and upload working with platformio
The hardware is the LoRa-E5 mini from seeed studio, contains the STM32WLE5JC:
Pins:
  • PA4/PA5: radio rx/tx?
  • PB6/PB&: serial port
  • PB5: onboard LED
  • PB13: onboard button ("BOOT")
  • PA4: internal SUBGHZ SPI NSS, conflicts with RX/TX switch?
  • PA5: internal SUBGHZ SPI SCK, conflicts with RX/TX switch?
  • PA6: internal SUBGHZ SPI MISO
  • PA7: internal SUBGHZ SPI MOSI
LoRa modem
It appears the LoRa functionality is exposed through an internal SPI bus, called SUBGHZSPI in the datasheet.
Also, there are some pins to control the radio path.
Programming over SWD
Connect an ST-LINKv2 as follows:
  • SWDIO to PA13
  • SWCLK to PA14
  • GND to GND
Initial experimental firmware can be found at: https://github.com/bertrik/lora-e5
  • blinky example, the most basic of all sketches which makes a LED blink demonstration of successful download of an Arduino program
  • helloworld example, sends a text over the serial port
These examples still uses the Arduino IDE, with a 'generic' STM32WLE5JCI.
There appears to be support for various kinds of WL55 boards in the stm32duino project: https://github.com/stm32duino/Arduino_Core_STM32/blob/main/boards.txt
Support for a generic WLE5JCI board here in the stm32duino archive: https://github.com/stm32duino/Arduino_Core_STM32/blob/main/variants/STM32WLxx/WL54JCI_WL55JCI_WLE4J(8-B-C)I_WLE5J(8-B-C)I/boards_entry.txt#L62
How to add a new variant (board): https://github.com/stm32duino/wiki/wiki/Add-a-new-variant-(board)
Experimental development environment
This uses my own fork, which will include support for the Seeed LoRa E5 mini.
Now you can:
  • Load the helloworld.ino file into the Arduino IDE:
    • Compile and upload with ctrl-U
    • Open serial port with ctrl-shift-M and see that serial messages are coming in
Getting it to work
Got a flashing LED sketch to work:
  • install Arduino IDE, e.g. 1.8.16
  • install the STM32 support
    • add through menu File / Preferences / Additional board manager URLs
 https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json
    • under menu Tools / Board / Board manager, search for stm32 and install the board package
  • select the right board:
    • WLE5JCIx
  • upgrade the firmware of my stlink2 (tool from ST), currently at V2J38S7
  • run the cubestm environment to use the stlink2 to disable the firmware protection
  • flash a simple blinky sketch to the board
Serial port does not work yet, it is connected to PB6/PB7. I need to configure an alternative setting for the pins, don't know exactly how to do that on Arduino:
Node configuration in TheThingsNetwork
