LoRa-E5-mini
| Project LoRa E5 | |
| Arduino on the LoRa-E5 module | |
| Last Update | 2021-10-09 |
The plan
- replace the original "AT" firmware with Arduino based firmware
- use the BasicMac library for LoRaWAN
- use platformio as the build system
- create some basic examples for use as a LoRaWAN node on TheThingsNetwork
The hardware is the LoRa-E5 module from seeed studio, contains the STM32WLE5JC:
- LoRa E5 module (just the chip): https://www.seeedstudio.com/LoRa-E5-Wireless-Module-p-4745.html
- LoRa E5 mini dev board: https://www.seeedstudio.com/LoRa-E5-mini-STM32WLE5JC-p-4869.html
- LoRa E5 wiki page: https://wiki.seeedstudio.com/LoRa-E5_STM32WLE5JC_Module/
- FCC information about the module: https://fccid.io/Z4T-LORA-E5/
https://github.com/bertrik/lora-e5
There appears to be support for various kinds of WL55 boards: https://github.com/stm32duino/Arduino_Core_STM32/blob/main/boards.txt
Support for this board in this archive: https://github.com/dolfandringa/Arduino_Core_STM32/blob/master/variants/STM32WLxx/WL54JCI_WL55JCI_WLE4J(8-B-C)I_WLE5J(8-B-C)I/boards_entry.txt#L62 ???
Development environment
- Install Arduino IDE, from https://www.arduino.cc/en/software
- Add a board URL: https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json
- Under menu Tools/Board/Boards manager, search for STM32 and install 'STM32 MCU based boards'
- Under menu Tools/Board/STM32 boards, choose 'Generic STM32WL series', then 'Generic STM32WL series'
- Under menu Tools/Board part number, choose Generic WLE5JCIx'
Load the .ino file. Compile with ctrl-R.
Programming over SWD
Connect an ST-LINKv2 as follows:
- SWDIO to PA13
- SWCLK to PA14
- GND to GND
Hold BOOT, then press RST and execute:
openocd -s /usr/share/openocd/scripts -f interface/stlink.cfg -f target/stm32wlx.cfg
Result:
Open On-Chip Debugger 0.11.0 Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'. Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD Info : Listening on port 6666 for tcl connections Info : Listening on port 4444 for telnet connections Info : clock speed 500 kHz Info : STLINK V2J17S4 (API v2) VID:PID 0483:3748 Info : Target voltage: 3.258730 Info : stm32wlx.cpu: hardware has 6 breakpoints, 4 watchpoints Info : starting gdb server for stm32wlx.cpu on 3333 Info : Listening on port 3333 for gdb connections
Or program over serial?
Getting it to work
Got a flashing LED sketch to work:
- install Arduino IDE
- install the STM32 support
- choose the right board
- upgrade the firmware of my stlink2 (tool from ST)
- run the cubestm environment to use the stlink2 to disable the firmware protection
- flash a simple blinky sketch to the board
Node configuration in TheThingsNetwork
