Treinonderdelen
Project Treinonderdelen | |
Status | Initializing |
Contact | Sebastius |
Last Update | 2020-12-29 |
Catalogus
Coordinatie
Inschrijflijst
Treindisplay intern
- Beschikbaarheid
- Totale aantal: 1908 Afname mogelijk: 492 Frequentie: Per tranche
- Min. afname: 100 stuks Locatie: n.t.b.
- Specificaties
- Materiaal: Aluminium, PC, RVS
- Lengte: 707 mm Breedte: 121 mm Diepte:60 mm
Nickname | Hackerspace | How to contact | Number of units |
Sebastius | Revspace | IRC #revspace Sebastius | 3 |
Jolo | Bitlair | TBA (via polyfloyd) | 1 |
h3x4d3c1m4l | Revspace | Telegram @h3x4d3c1m4l | 2 |
minicom | Revspace | IRC minicom | 1 |
Niels | via minicom | IRC minicom | 1 |
PBX | Revspace | PBX | 1 |
bef0re | Hackalot/RevSpace | IRC | 3 |
Martian | TkkrLab / Hackalot | IRC #tkkrlab martian | 1 |
Archels | Hack42 | Archels in #hack42 | 1 |
Boots | nurdspace | IRC #nurds Boots | 1 |
pietdv | Revspace | piet_at_devae.re | 2 |
rad0 | TechInc | ? | 1 |
Wizzup | TechInc | ? | 1 |
eightdot | Bitlair | IRC | 2 |
Wheeze_NL | RevSpace | IRC | 2 |
Xesxen | Hackalot | IRC | 1 |
Flimpie | via Polyfloyd | Telegram @flippylosaurus | 4 |
Bix | Hack42 | IRC | 4 |
CrazyA | Frack | IRC | 3 |
Dreamer | NurdSpace | IRC | 1 |
Stoneshop | Hack42 | IRC | 1 |
qguv | Revspace | IRC qguv@freenode | 1 |
Gopper | Bitlair | Telegram @robmans | 2 |
XNDR | RevSpace | Phone | 8 |
FooBar | Revspace | IRC | 2 |
Sake Blok | badge.team | telegram @kolbekas | 1 |
Kevin | via minicom | Telegram @GKHill | 1 |
rad0 | techinc | 1 | |
kmhn | AwesomeSpace | Telegram @knassar | 2 |
Mikazuki | Frack | IRC #Frack | 2 |
skier | ? | IRC #2600 irc.smurfnet.ch | 3 |
TE LAAT maar misschien blijft er wat over. | ? | ? | ? |
Current Total | 60 |
Noodremhandel
- Beschikbaarheid
- Totale aantal: 1329 Afname mogelijk: 740 Frequentie: Per tranche
- Min. afname:50 stuks Locatie: nntb
Sebastius | Revspace | ? | 2 |
Benadski | Revspace | ? | 4 |
Boekenwuurm | Revspace | ? | 2 |
Juerd | Revspace | ? | 1 |
PBX | Revspace | ? | 2 |
Lucanator | Revspace | ? | 1 |
Quint (not qguv) | via minicom | IRC minicom | 1 |
H3x<tab> | Revspace | ? | 2 |
thomas | Revspace | ? | 2 |
cmpxchg | Revspace | ? | 1 |
Martian | TkkrLab / Hackalot | IRC #tkkrlab martian | 2 |
Muse | TechInc | userpage op techinc wiki | 6 |
polyfloyd | Bitlair | IRC | 2 |
eightdot | Bitlair | IRC | 1 |
forseti | Bitlair | IRC #bitlair | 3 |
effractuur | ? | IRC | 10 |
bertrik | Revspace | IRC #revspace | 1 |
Xesxen | Hackalot | IRC | 2 |
jelly | Revspace | IRC #revspace | 1 |
Stoneshop | Hack42 | IRC | 2 |
Dreamer | Nurdspace | IRC | 3 |
Kartoffel | Revspace | IRC #revspace | 1 |
Anus | Revspace | IRC #revspace | 1 |
Katje | TechInc | IRC | 1 |
Renze | Tkkrlab | Telegram @r3nz3 | 2 |
Ultratux | Techinc | IRC | 1 |
Molenaar | Revspace | e-mail/wiki | 2 |
Linor | Bitlair | IRC #bitlair | 1 |
Pwuts | Revspace | IRC | 4 |
Braldt | via minicom | Telegram @Braldt | 1 |
Hans | via minicom | ? | 1 |
Casper | via minicom | Telegram @MrSnowman | 1 |
Flimpie | via PolyFloyd | Telegram @flippylosaurus | 1 |
Meathur | via f0x | Telegram @Meathur | 1 |
chip | techinc | 2 | |
DWizzy | respace? | Mail, Tg, xmpp | 2 |
bef0re | Hackalot/RevSpace | IRC | 8 |
Mikazuki | Frack | IRC #Frack | 1 |
fhp | hackalot | IRC #hackalot | 1 |
Okkie | Revspace | postduif? | 2 |
Redlizard | Hackalot | IRC | 1 |
Current Total | 91 |
Deurbedieningspaneel
minimale afname 50 stuk, bod 10,- p/s
webmind | techinc | irc | 2 |
Wizzup | techinc | irc | 3 |
effractuur | ? | IRC | 2 |
minicom + Niels | RevSpace | irc | 2 |
Wheeze_NL | RevSpace | irc | 2 |
Xesxen | Hackalot | irc | 2 |
Ultratux | Techinc | IRC | 2 |
Boekenwuurm | Hackalot | irc | 1 |
Linor | Bitlair | IRC #bitlair | 2 |
Pwuts | Revspace | IRC | 1 |
holysn0w | via minicom | Telegram @holysn0w | 1 |
Kevin | via minicom | Telegram @GKHill | 2 |
Flimpie | via PolyFloyd | Telegram @flippylosaurus | 2 |
thomas | RevSpace | irc | 1 |
Meathur | via f0x | Telegram @Meathur | 3 |
chip | techinc | 1 | |
DWizzy | respace? | Mail, Tg, xmpp | 3 |
bef0re | Hackalot/RevSpace | IRC | 1 |
Redlizard | hackalot | IRC | 1 |
skier | ? | IRC #2600 irc.smurfnet.ch | 2 |
Muse | TechInc | userpage op techinc wiki | 2 |
Current Total | 52 |
Treindisplay extern (It's bigger!)
Minimumafname 60 stuks, a 25 euro per stuk (dat is het minimale bod per unit met een beetje marge).
- Beschikbaarheid
- Totale aantal: 348 Afname mogelijk: 200 Frequentie: Per tranche
- Min. afname: 60 stuks Locatie: n.t.b.
- Specificaties
- Lengte: 1002 mm Breedte: 206 mm Diepte: 66,5 mm
- Display: 160,7 x 948 mm
minicom (Niels) | RevSpace | IRC | 1 |
Dreamer | Nurdspace | IRC | 1 |
h3x4d3c1m4l | RevSpace | Telegram @h3x4d3c1m4l | 2 |
Eightdot | Bitlair | IRC | 2 |
bef0re | Hackalot/RevSpace | IRC | 4 |
qguv | Revspace | IRC | 1 |
You? | ? | ? | ? |
Current Total | 18 |
Foto's en andere info, nog te sorteren
https://revspace.nl/kiekjes/view/20201221/P1020214.JPG
https://revspace.nl/kiekjes/view/20201221/P1020213.JPG
https://revspace.nl/kiekjes/view/20201221/P1020212.JPG
Research
Displays
Connectors display (AMP):
- 178289-6 (Power/ID Select, gelabeld X1 op de displays) - 2-178128-3 (RS485 OUT, Y key, gelabeld X2 op de displays, degene aan de bovenkant) - 1-178128-3 (RS485 IN, X key, gelabeld X2 op de displays, degene aan de onderkant) - (1-)175216-{2,3,5} AWG 24/26/28 pin (-5 is tin, de andere 2 is verguld) - (1-)175217-{2,3,5} AWG 20/22/24 pin (^)
Note: Je hebt de RS485-OUT connector helaas nodig om een eindweerstand aan te brengen
X1
/-------------------\ A | 1 - 3 4 5 6 | B | 1 2 3 4 5 6 | --------------------- A1 - Power GND B1 - Power Vcc (110V DC nominaal, zie comment hieronder) B2 - NC 3: Addr0 4: Addr1 5: Addr2 6: Addr3
Pins 3-6 zijn configuratiebits: bridge ze om een 1 te vormen, laat ze om een 0 te vormen. Samen vormen ze het 4-bit adres van het scherm op de displaybus.
Het scherm heeft eem DC-DC converter intern (VE-JTY-EW). Aldus de spec van deze trafo mag daar 66-160V DC in.
X2
/-------\ Y | 1 2 3 | |-------| X | 1 2 3 | --------- X1: RS485 IN- X2: RS485 IN+ Y1: RS485 OUT- Y2: RS485 OUT+ 3: GND
De displays zijn gedaisy-chaind aan hun bus: op rij X komt een RS485-signaal binnen, dat via rij Y weer aan rij X van het volgende display gevoerd wordt. Bij het laatste display is rij Y getermineerd.
Testmodus
De panelen kan in testmodus gebracht worden door Address 15 te selecteren op de X1 connector. Deze modus heeft een "sweep" demo er in zitten waarmee je kan zien of je paneel geheel functioneert.
Deze modus schijnt ook te triggeren te zijn over RS485, maar het protocol is vooralsnog onbekend.
