Treinonderdelen
| Project Treinonderdelen | |
| Status | Initializing |
| Contact | Sebastius |
| Last Update | 2019-11-17 |
Catalogus
Coordinatie
Inschrijflijst
Treindisplay intern
- Beschikbaarheid
- Totale aantal: 1908 Afname mogelijk: 492 Frequentie: Per tranche
- Min. afname: 100 stuks Locatie: n.t.b.
- Specificaties
- Materiaal: Aluminium, PC, RVS
- Lengte: 707 mm Breedte: 121 mm Diepte:60 mm
| Nickname | Hackerspace | How to contact | Number of units |
| Sebastius | Revspace | IRC #revspace Sebastius | 3 |
| Jolo | Bitlair | TBA (via polyfloyd) | 1 |
| h3x4d3c1m4l | Revspace | Telegram @h3x4d3c1m4l | 2 |
| minicom + Niels | Revspace | IRC #revspace minicom | 2 |
| PBX | Revspace | PBX | 1 |
| Bef0re | Revspace | bef0re | 3 |
| Martian | TkkrLab / Hackalot | IRC #tkkrlab martian | 1 |
| Archels | Hack42 | Archels in #hack42 | 1 |
| Boots | nurdspace | IRC #nurds Boots | 1 |
| thomas | Revspace | IRC #revspace thomastheo | 1 |
| pietdv | Revspace | piet_at_devae.re | 2 |
| rad0 | TechInc | ? | 1 |
| Wizzup | TechInc | ? | 1 |
| eightdot | Bitlair | IRC | 2 |
| Wheeze_NL | RevSpace | IRC | 2 |
| Xesxen | Hackalot | IRC | 1 |
| Flimpie | via Polyfloyd | Telegram @flippylosaurus | 3 |
| Bix | Hack42 | IRC | 4 |
| CrazyA | Hack42 | IRC | 1 |
| Dreamer | NurdSpace | IRC | 1 |
| Stoneshop | Hack42 | IRC | 1 |
| qguv | Revspace | IRC qguv@freenode | 1 |
| You? | ? | ? | ? |
| Current Total | 36 |
Noodremhandel
- Beschikbaarheid
- Totale aantal: 1329 Afname mogelijk: 740 Frequentie: Per tranche
- Min. afname:50 stuks Locatie: nntb
| Nickname | Hackerspace | How to contact | Number of units | ||||
| Sebastius | Revspace | ? | 2 | ||||
| Benadski | Revspace | ? | 4 | ||||
| Boekenwuurm | Revspace | ? | 2 | ||||
| Juerd | Revspace | ? | 1 | ||||
| PBX | Revspace | ? | 2 | ||||
| Lucanator | Revspace | ? | 1 | ||||
| minicom + Niels + Hans + Quint (not qguv) | Revspace | IRC #revspace minicom | 4 | ||||
| H3x<tab> | Revspace | ? | 2 | ||||
| thomas | Revspace | ? | 2 | ||||
| cmpxchg | Revspace | ? | 1 | ||||
| Martian | TkkrLab / Hackalot | IRC #tkkrlab martian | 2 | ||||
| Archels | Hack42 | Archels in #hack42 | 1 | ||||
| Muse | TechInc | userpage op techinc wiki | 4 | ||||
| polyfloyd | Bitlair | IRC | 2 | ||||
| rowan8k | Revspace | IRC | 1 | ||||
| eightdot | Bitlair | IRC | 1 | ||||
| forseti | Bitlair | IRC #bitlair | 2 | ||||
| effractuur | ? | IRC | 2 | ||||
| bertrik | Revspace | IRC #revspace | 1 | ||||
| Xesxen | Hackalot | IRC | 1 | ||||
| jelly | Revspace | IRC #revspace | 1 | ||||
| Stoneshop | Hack42 | IRC | 2 | ||||
| Dreamer | Nurdspace | IRC | 3 | ||||
| Kartoffel | Revspace | IRC #revspace | 1 | Anus | Revspace | IRC #revspace | 1 |
| You? | ? | ? | ? | ||||
| Current Total | 45 |
Deurbedieningspaneel
minimale afname 50 stuk, bod 10,- p/s
| webmind | techinc | irc | 1 | ||||
| Wizzup | techinc | irc | 3 | ||||
| minicom + Niels | RevSpace | irc | 2 | ||||
| Wheeze_NL | RevSpace | irc | 2 | ||||
| Xesxen | Hackalot | irc | 2 | ||||
| Stoneshop | Hack42 | IRC | 1 | ||||
| Anus | Revspace | IRC #revspace | 1 | Current Total | 17 |
Treindisplay extern (It's bigger!)
Minimumafname 60 stuks, a 25 euro per stuk (dat is het minimale bod per unit).
- Beschikbaarheid
- Totale aantal: 348 Afname mogelijk: 200 Frequentie: Per tranche
- Min. afname: 60 stuks Locatie: n.t.b.
- Specificaties
- Lengte: 1002 mm Breedte: 206 mm Diepte: 66,5 mm
- Display: 160,7 x 948 mm
| minicom (Niels) | RevSpace | IRC | 1 |
| Dreamer | Nurdspace | IRC | 1 |
| You? | ? | ? | ? |
| Current Total | 4 |
