ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38 | |
File:File:ZX81plus38 rev1.2 cropped.png | |
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% ZX-81 clone that anybody could build, with commonly available parts. | |
Status | Initializing |
Contact | mahjongg |
Last Update | 2019-10-16 |
October 1, 2019 continued
