TTNHABBridge
Project TTNHABBridge
A software bridge between TTN and the HAB network
Last Update 2019-05-18
A bridge application that accepts high altitude balloon telemetry data from TTN and forwards it to habhub.
May 2019: I've update the parsing for telemetry data encoded using 'cayenne LPP': it now simply places all cayenne fields in the UKHAS sentence, in the order they appears in the cayenne messages, like this:
 $$name,sequence,time,field,field,...,field*checksum\n
This way you have some control over what is sent to UKHAS. I recommend to place the GPS field first in the Cayenne LPP message.
In the current situation, high altitude balloons send telemetry on the 434 MHz band using RTTY modulation. Dedicated receivers listening for RTTY-modulated ASCII strings. The operator of each receiver (typically radio amateurs) has to prepare his radio setup for receiving the telemetry, by tuning to the correct frequency at the correct time, setting up a dedicated software client that decodes the RTTY modulation and forwards the data to a central system over the internet.
In the new situation, the existing infrastructure of TheThingsNetwork is used to receive low-bitrate telemetry packets and forward them on the internet. It uses LoRa as a modulation scheme which allows for very small transmission power and is much less susceptible to slight tuning errors than the currently used RTTY modulation. This means that telemetry packets can be received completely autonomously by TTN gateways, no need for a radio operator to make adjustments etc.
In short, the idea is:
  • you attach a LoRaWAN transmitter to the balloon, which been pre-configured with a set of keys generated by the TTN
  • the balloon broadcasts its telemetry every once in a while (say a few times per minute) and this is picked up by one or more TTN gateways which forward into the TTN infrastructure
  • the bridge software converts each telemetry packet according to 'UKHAS' conventions and forwards it to the habitat.habhub.org server
  • the bridge software also forwards the TTN gateway locations, so they also appear on the map, along with their name / EUI and antenna altitude
  • the habitat.habhub.org server still sees the same messages like it would if there were many traditional receivers, so doesn't need any modification!
This way, the entire things network can be used to receive balloon telemetry! There is no longer a need for radio operators to be present at their receiver at the exact time the balloon is launched, making manual adjustments, etc. The Netherlands is already covered by many TTN gateways, greatly increasing the chance the balloon telemetry will be picked up.
Source code
Using this source code, the basic functionality works.
There is no user guide yet, but the .properties settings file has a one-line comment explaining what each setting does.
Building the software
Steps (on Linux):
  • install a java-11 JDK
 sudo apt-get install openjdk-11-jdk
  • clone the software from github
 git clone https://github.com/bertrik/ttnhabbridge
  • enter director ttnhabbridge/gradle
  • run the gradle script to build the executable
 ./gradlew distTar
  • the executable is now available at ttnhabbridge/build/distributions/ttnhabbridge.tar
Design
Main process
  • once we get data:
    • for each gateway that received the data:
      • send a listener info and a listener telemetry document to the habhub server
      • send the payload telemetry (ASCII sentence) to the habhub server
MQTT listener
Implemented using the Eclipse paho MQTT client. We can listen on a certain application and catch *all* traffic for all nodes registered to that application.
Example invocation, using mosquitto_sub:
 bertrik@zenbook:~$ mosquitto_sub -h eu.thethings.network -t '+/devices/+/up' -u 'ttnmapper' -P 'ttn-account-v2.Xc8BFRKeBK5nUhc9ikDcR-sbelgSMdHKnOQKMAiwpgI' -v
Actual result:
 ttnmapper/devices/mapper2/up {"app_id":"ttnmapper","dev_id":"mapper2","hardware_serial":"0004A30B001ADBC5","port":1,"counter":1,"payload_raw":"d4WaWXATAAAAAAAAAAAAAAAAAAD/","metadata":{"time":"2017-08-21T07:02:14.842855925Z","frequency":868.1,"modulation":"LORA","data_rate":"SF7BW125","coding_rate":"4/5","gateways":[{"gtw_id":"eui-008000000000b8b6","timestamp":865620531,"time":"2017-08-21T07:02:14.846095Z","channel":0,"rssi":-119,"snr":-3.8,"rf_chain":1,"latitude":52.0182,"longitude":4.70844,"altitude":27}]}}
 ttnmapper/devices/mapper2/up {"app_id":"ttnmapper","dev_id":"mapper2","hardware_serial":"0004A30B001ADBC5","port":1,"counter":4,"payload_raw":"loeaWW4T2+8BHzYZzAIeAA8A/QUS","metadata":{"time":"2017-08-21T07:11:18.313946438Z","frequency":868.3,"modulation":"LORA","data_rate":"SF7BW125","coding_rate":"4/5","gateways":[{"gtw_id":"eui-008000000000b8b6","timestamp":1409115451,"time":"2017-08-21T07:11:18.338662Z","channel":1,"rssi":-114,"snr":-0.2,"rf_chain":1,"latitude":52.0182,"longitude":4.70844,"altitude":27}]}}
Habitat uploader
The habitat interface is accessed as a REST service, using a combination of Jetty/Jersey/Jackson Java libraries.
payload upload
This uses a HTTP interface, performing a PUT to a certain URL with a certain content:
  • the URL is http://habitat.habhub.org/habitat/_design/payload_telemetry/_update/add_listener/<doc_id>
  • the <doc_id> is created from the telemetry sentence by doing ASCII to BASE64 conversion, then hashing using SHA-256 and encoding as ASCII-hex (as LOWER case!).
  • the HTTP method is a PUT with the following headers:
    • "Accept: application/json"
    • "Content-Type: application/json"
    • "charsets: utf-8"
  • The contents of the PUT is the following JSON structure
  "data": {
  "receivers": {
    "[receiver_id]": {
listener upload
To figure out how to upload information about the receiver station, I captured some traffic between dl-fldigi and habitat, the following happens:
  • a GET is done on http://habitat.habhub.org/_uuids?count=100, this returns a list of 100 UUIDs, where a UUID is the lower-case ascii hex representation of 16 bytes.
  • a PUT is done with a "listener_information" doc to /habitat/<the first UUID>
  • a PUT is done with a "listener_telemetry" doc to /habitat/<the second UUID>
This is implemented with an expiring cache, so listener information/telemetry is uploaded regularly (say every 20 minutes) but not with *every* payload telemetry.
Payload encoder/decoder
The bridge application currently allows the following encodings for the telemetry data, configurable in the application properties:
See the table and example below to know which fields are required to construct the habitat ASCII sentence from the LoRa data payload sent by your tracker.
 $$ttntest1,64,20:41:10,52.022100,4.693100,20.0,14.0,3.88*1C8A
Property mapping
Field value SodaqOne raw JSON Cayenne Remark
ttntest1 TTN node name TTN node name TTN node name TTN node name
64 LoRaWAN FCNT LoRaWAN FCNT LoRaWAN FCNT Frame count
20:41:10 field 0 TTN metadata time TTN metadata time TTN metadata time
52.022100 field 3 "lat" see below latitude (degrees)
4.693100 field 4 "lon" see below longitude (degrees)
20.0 field 5 "gpsalt" see below altitude (meters)
14.0 field 2 "temp" see below temperature (degrees Celcius)
3.88 field 1 "vcc" see below battery voltage (volts)
The field 1C8A is the CCITT-CRC16 over the characters between $$ and *, interpreted as bytes using US-ASCII encoding
Listener cache
Listener information / telemetry is sent only:
  • when this is the first time we are sending something for this listener
  • when it has been more than X minutes ago that we sent listener information / telemetry for this listener, where X is typically 10 minutes or so.
Helpful links
20:24 < adamgreig> there's a) a python library that's a lot easier to read
20:24 < adamgreig> but b) basically the gist is you just PUT to http://habitat.habhub.org/habitat/_design/payload_telemetry/_update/add_listener/<id> with some stuff
20:24 < adamgreig> http://habitat.readthedocs.io/en/latest/habitat/habitat/habitat/habitat.views.payload_telemetry.html#module-habitat.views.payload_telemetry
20:24 < adamgreig> so you have a new string, you take the sha256 hex digest of the base64 encoded raw data
20:25 < adamgreig> you PUT to that URL with that ID
20:25 < adamgreig> and you include that JSON struture with your callsign/details
list of habitat JSON schemas
JSON examples
MQTT data
Over MQTT, it looks like this:
  "app_id": "ttnmapper",
  "dev_id": "mapper2",
  "hardware_serial": "0004A30B001ADBC5",
  "port": 1,
  "counter": 587,
  "payload_raw": "g3ybWXkTef8BH1EOzAK1\/wEA5wQT",
  "metadata": {
    "time": "2017-08-22T00:36:18.674804288Z",
    "frequency": 868.1,
    "modulation": "LORA",
    "data_rate": "SF7BW125",
    "coding_rate": "4\/5",
    "gateways": [
        "gtw_id": "eui-008000000000b8b6",
        "timestamp": 3979529499,
        "time": "2017-08-22T00:36:18.345616Z",
        "channel": 0,
        "rssi": -120,
        "snr": -7,
        "rf_chain": 1,
        "latitude": 52.0182,
        "longitude": 4.70844,
        "altitude": 27
Tracker configuration for the TTN-HAB bridge software
  • setup your LoRaWAN device for use with TheThingsNetwork
  • create a payload configuration document on the habhub.org webpage
  • download, configure and run the ttnhabbridge software
Setting up the tracker for TTN
  • specifically for the SodaqOne, the EUI (LoRaWAN hardware address) is shown at startup of the tracker
  • perhaps just make up your own, if you don't use an RN2483?
Create the TTN application and register your tracker with TTN:
  • Create an account on TTN, https://account.thethingsnetwork.org/
  • Go to the TTN console and create a new application, or select an existing application you want to add the device to.
  • create a new node/device, the name needs to be equal to the habhub payload name (but cannot use uppercase characters)
  • In the device settings screen:
    • under 'Device EUI', fill in the EUI of your LoraWAN tracker
    • under 'Activation method' choose ABP
    • disable option 'Frame Counter Checks'
    • click Save
  • this means the "device address", "network key" and "application key"
  • in case you use a SodaqOne serial debug console, type the following:
    • copy the Network Session Key from the TTN console and type in the SodaqOne serial debug console 'key=<key>'
    • copy the App Session Key from the TTN console and type in the SodaqOne serial debug console 'app=<key>'
    • copy the device id from the TTN console and type in the SodaqOne serial debug console 'dev=<deviceid>' (is this right?)
  • configure the following additional settings in the SodaqOne:
    • enable ABP mode (disable OTAA), by typing 'otaa=0'
    • set spreading factor 7: 'sf=7'
    • disable ADR: 'adr=0'
    • enable GPS: 'gps=1'
    • set GPS fix interval: 'fi=1'
    • set GPS fix timeout: 'gft=30'
    • set GPS satellite count: 'num=1'
Creating a payload configuration document
Steps:
  • Go to the habhub habitat website and create new payload document
  • under 'payload name' fill in the callsign (e.g. 'ttntest1'), this has to match exactly with the TTN node name
    • add a parser configuration, using the new format wizard
    • enter the following example string: $$ttntest1,64,20:41:10,52.022100,4.693100,20.0,14.0,3.88*1C8A
  • the fields are the following:
    • sentence id
    • time
    • all of the Cayenne fields in the order they appear in the Cayenne message.
  • click save
So, this contains the basic position information, plus two fields for temperature and battery level. Other properties are currently not supported.
Configuring the TTN-HAB bridge software
  • get the release zip file and unzip it in some place
  • make sure you have Java 8 installed
  • In the bridge configuration properties file (ttnhabbridge.properties), fill in the following
    • ttn.app.id with the name of your TTN application
    • ttn.app.key with the key of your TTN application (you can find this in the TTN console)
    • ttn.payload.encoding with the type of payload encoding you use
    • you can probably leave the other settings at their default value
  • start the bridge software from the command line, either using the .bat file (for windows) or the .sh file (for Linux)
  • if you use Linux with systemd, you can use the ttnhabbridge.service file to run it as a service, see instructions inside this file
