Spacestategeschiedenis
Data file:
- First 8 bytes (64 bit): unix time_t epoch time of first data point
- Subsequent data: one byte per minute, byte offset = 8 + floor((time() - $start_time) / 60)
- ASCII '0': space was closed (or mostly closed)
- ASCII '1': space was open (or mostly open)
- ASCII '?': script did run but could not determine space state (not currently in use)
- ASCII '\0' (NUL): space state was not recorded
- Any other value: treat as '?'
Subprojecten:
- Statelogger en dump van heatmaps (Juerd)
- Source: https://github.com/revspace/statelogger
- Draait op gateway vanuit /home/juerd/statelogger
- statelogger draait elke minuut
- create-heatmaps draait elk kwartier
- Importeren van oude space-states (Juerd, eightdot)
- Bron 1: twitter (ca. 2010-01 - 2013-06)
- Bron 2: irc-logs (ca. 2012-05 - 2018-17)
- Ondanks diverse handmatige fixes klopt 't niet helemaal, maar goed genoeg voor bruikbare heatmaps.
- HTML/CSS van de heatmaps (f0x)
- Work in progress
Statelog na iets minder dan 18 uur loggen: (* = meer van hetzelfde)
00000000 ce 39 24 5b 00 00 00 00 31 31 31 31 30 30 30 30 |.9$[....11110000| 00000010 30 30 31 31 31 31 31 31 31 31 31 31 31 31 31 31 |0011111111111111| 00000020 30 30 30 31 31 31 31 31 31 31 31 31 31 31 31 31 |0001111111111111| 00000030 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 |1111111111111111| * 00000240 31 31 31 31 31 31 31 31 31 31 31 31 30 30 31 31 |1111111111110011| 00000250 31 31 31 31 31 30 30 30 30 30 30 30 30 30 30 30 |1111100000000000| 00000260 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 |0000000000000000| * 000002d0 30 30 30 30 30 30 31 31 31 31 31 31 31 31 31 31 |0000001111111111| 000002e0 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 |1111111111111111| * 00000433
