Luteijn/Vortex
< Luteijn
Project "Vortex":
| Project Luteijn/Vortex | |
| Contact | Luteijn |
| Last Update | 2018-01-31 |
What's connected to the pins
| 0 | Serial RX (input) |
| 1 | Serial TX (output) |
| 2 | Encoder Wheel (External Interrupt 0) (input) |
| 3 | Encoder Wheel (External Interrupt 1) (input) |
| 4 | ?? mp3 RX (input) hopefully but don't know. |
| 5 | Motor 0 Speed (PWM) (output) |
| 6 | Motor 1 Speed (PWM) (output) |
| 7 | IR decoder/detector (input) |
| 8 | IR led Left (output) |
| 9 | Motor 0 direction (H=forwards,L=reverse) (output) |
| 10 | Motor 1 direction (output) |
| 11 | MP3-player TX (output) |
| 12 | IR led Right (output) |
| 13 | GRB LED chain around body (output) |
| A0 | grayscale 4 'D' (input) |
| A1 | grayscale 3 'C' (input) |
| A2 | grayscale 2 'B' (input) |
| A3 | grayscale 1 'A' (input) |
| A4 | SDA (i2c) |
| A5 | SCL (i2c) |
| A6 | grayscale 5 'E' (input) |
| A7 | grayscale 6 'F' (input) |
Motor Control
int E1 = 5;
int M1 = 9;
int E2 = 6;
int M2 = 10;
void setup()
pinMode(M2, OUTPUT);
void loop()
int value;
for(value = 0 ; value <= 255; value+=5) //foreward
digitalWrite(M1,HIGH);
digitalWrite(M2, HIGH);
analogWrite(E1, value); //PWM Speed control
analogWrite(E2, value); //PWM Speed Control
delay(30);
for(value = 0 ; value <= 255; value+=5) //backward
digitalWrite(M1, LOW);
digitalWrite(M2, LOW);
delay(30);
Encoders
long leftPul,rightPul;
void leftCallBack(){
leftPul++;
void rightCallBack(){
rightPul++;
void initDdevice(){
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
noInterrupts();
interrupts();
void motorDebug(){
digitalWrite(5,HIGH);
digitalWrite(6,HIGH);
digitalWrite(9,HIGH);
digitalWrite(10,HIGH);
void printPul(){
Serial.print(leftPul);
Serial.print(" ");
Serial.println(rightPul);
leftPul = 0;
rightPul = 0;
void setup() {
initDdevice();
Serial.begin(9600);
motorDebug();
void loop() {
printPul();
delay(500);
Analogue Inputs
2 (a2) 3 (a1)
1 (a3) 4 (a0)
5 (a6) 6 (a7)
void setup(void){
Serial.begin(9600);
int analogBuf[6] = {'\0'};
void loop(void){
analogBuf[0] = analogRead(3);
analogBuf[1] = analogRead(2);
analogBuf[2] = analogRead(1);
analogBuf[3] = analogRead(0);
analogBuf[4] = analogRead(6);
analogBuf[5] = analogRead(7);
for(int i=0;i<6;i++){
Serial.print(i+1);
Serial.print(": ");
Serial.print(analogBuf[i]);
Serial.print(" ");
Serial.println();
delay(500);
LEDs
FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, NUM_LEDS);
IR obstacle detector
Seems to be somewhat flaky. Needs a bit more work to figure out. Also, the IR sensor might be useful to read IR remote controllers or beacons. This receiver seems to work at 38kHz, but probabbly also reacts to 36-40kHz. Remote controllers often work at 36kHz. Note that 2x 8µs delay doesn't give you 38kHz, but the digitalWrite itself also induces quite some delay (3-6µs), so seems this is bringing the total period up to around the 26.something µs we'd expect.
#define NUM_LEDS 12
// Data pin that led data will be written out over
#define DATA_PIN 13
CRGB leds[NUM_LEDS];
#define IR_IN 7//IR receiver pin
#define L_IR 8 //left ir transmitter pin
int count;
int i;
for(i=0;i<24;i++){
digitalWrite(L_IR,LOW);
delayMicroseconds(8);
digitalWrite(L_IR,HIGH);
int i;
for(i=0;i<24;i++){
digitalWrite(R_IR,LOW);
digitalWrite(R_IR,HIGH);
PCICR |= 1 << PCIE2;
count++;
void obstacleAvoidance(void){
char i;
count=0;
leds[5] = CRGB::Green;
FastLED.show();
for(i=0;i<20;i++){ //left transmitter sends 20 pulses
leftSend38KHZ();
delayMicroseconds(600);
leds[5] = CRGB::White;
FastLED.show();
Serial.println("Left");
delay(100);
count=0;
leds[3] = CRGB::Green;
FastLED.show();
rightSend38KHZ();
leds[3] = CRGB::White;
FastLED.show();
Serial.println("Right");
delay(100);
delay(600);
void setup(void){
delay(2000);
Serial.begin(9600);
leds[4] = CRGB::Blue;
FastLED.show();
delay(2000);
leds[4] = CRGB::Purple;
FastLED.show();
noInterrupts();
pcint0Init();
interrupts(); //enable the interrupt
void loop(void){
obstacleAvoidance();
IRreceiver
#include "IRremote.h"
IRrecv irrecv(IR_IN);
decode_results results;
void setup(void){
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
void loop(void){
if (irrecv.decode(&results)) {
irrecv.resume(); // Receive the next value
MP3-player
There is an MP3.player integrated in the robot. It can be controlled by sending more or less magic commands over software Serial via pin 11. Pin 2 might be connected to the player too if the example I found can be believed, but my tests so far never had anything received there (like an end of song reached, or even just an 'ack'), or when trying to get version information out. Anyway, D2 is connected to one of the wheel encoders, so not likely to be the RX. Maybe it's 12 or 10?
An example found on the DFRobot site:
#define MP3_VOLUME 0x10
#define TX 11
#define RX 4 // ?? 2 in example I found, but that is unlikely
#include <SoftwareSerial.h>
void setup()
delay(1000);
mp3Init();
mp3setVolume(30);//0~255
void loop()
mp3player(1);
delay(2000);
mp3stop();
delay(1000);
void mp3Init()
mySerial.begin (9600);
void mp3setVolume(byte vol)
mySerial.write(buffer, 8);
delay(20);
void mp3player(byte data)
delay(20);
void mp3stop()
https://www.dfrobot.com/product-1121.html , documented at https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299 is a mini-MP3 player form DFRobot. It is controllable over serial, and might be the same one as used in the Vortex. Would be good to figure out if the 'busy' signal is connected back to the arduino somewhere in that case. Player could also be a variant but the magic numbers more or less match (although the stop command 0x16 is not in the table. Perhaps Dec16 / 0x0A (standby/low power mode) was meant? The MP3-chip Part# is YX6100-24SS. Seems to be part of a family of serial MP3-players.
| $S | Start byte 0x7e | Each command begins with 0x7e ('~') |
| VER | Version information | Version seems to be 0xff from the example |
| Len | the number of bytes | Start, End and Checksum are not counted, |
| CMD | Commands | See command table. |
| Feedback | Command feedback | 1: feedback, 0: no feedback ; need to test what this does, might mean 'echo' |
| Para1 | Parameter 1 | Query high data byte |
| Para2 | Parameter 2 | Query low data byte |
| checksum | Checksum | accumulation and verification, doesn't include start byte. Seems to be 2 bytes from the example given in the docs, but Vortex seems to just not need it put in. example given is 7e ff 06 09 00 00 04 ff dd ef |
| $O | End byte | End of command is signaled with 0xEF |
uint16_t sum = 0;
sum += buffer[i];
return -sum;
Eyes
Besides 35 predefined eye patterns, it is also possible to upload your own eye patterns.
#include <Wire.h>
#define I2C_WRITE 0x00
uint8_t serial=0;
void setup(){
Wire.begin(); // join i2c bus (address optional for master)
defined_eyes(6,1);
delay(2000);
void loop(){
defined_eyes(1,serial);
serial++;
if(serial>=35) serial=0;
delay(250);
Wire.beginTransmission(I2C_LED_ADDRESS << 1 | I2C_WRITE); // transmit to device #4
Wire.write(serial); //preset eyes 0~34
Wire.endTransmission(); // stop transmitting
void custom_eyes(uint8_t color, uint8_t eyeline[10]){
uint8_t index;
// right eye left eye
//1 2 3 4 5 25 24 23 22 21
//6 7 8 9 10 20 19 18 17 16
//11 12 13 14 15 15 14 13 12 11
//16 17 18 19 20 10 9 8 7 6
//21 22 23 24 25 5 4 3 2 1
Wire.write(0x55); // color 55=custom eyes follow
Wire.write(0xAA); // ?? AA=color followed by 10 bytes, each defining one line
Wire.write(color&0x7); //color 1-B,2-G,4-R of foreground
for (index=0;index<10;index++) {
Wire.write(eyeline[index]);
void example_eyes() {
Wire.write(0x1c);
Wire.write(0x18);
Wire.write(0x10);
Wire.write(0x1f); // top row all 5 bits lit
Wire.write(0x0f); // leds 6,7,8,9 on 10 off
Wire.write(0x07); // 11,12,13 on, 14,15 off
Wire.write(0x03);
Wire.write(0x01);
