Lasercutter1
Versie door FooBar (overleg | bijdragen) op 16 jan 2012 om 23:40
Project Lasercutter
Contact Walter, FooBar, GMC
Last Update 2012-01-16
Lasercutter Checklist
  • Fans are turned on
  • The water is cool
Then, when making a print/cut
  • Do a test-run first, with the laser power disabled, to see if your design works without errors or hitting the borders
Where to get nice material for lasercutting
