UMD
| Project UMD | |
| Under Monitor Display hacks | |
| Contact | Eightdot, Sebastius |
| Last Update | 2016-11-14 |
todo
on Host
stty -F /dev/ttyUSB0 115200
C code:
./test CD 01 05 ff `echo Hoi RevSpace | perl -nle'print join " ", unpack("H*", $_) =~ /(..)/g'` > /dev/ttyUSB0
Perl code:
perl test.pl "Hoi RevSpace" > /dev/ttyUSB0
C code
#include <stdio.h>
#include <stdlib.h>
unsigned short crctbl[]={
0x0000, 0x1189, 0x2312, 0x329b, 0x4624, 0x57ad, 0x6536, 0x74bf,
0x8c48, 0x9dc1, 0xaf5a, 0xbed3, 0xca6c, 0xdbe5, 0xe97e, 0xf8f7,
0x1081, 0x0108, 0x3393, 0x221a, 0x56a5, 0x472c, 0x75b7, 0x643e,
0x9cc9, 0x8d40, 0xbfdb, 0xae52, 0xdaed, 0xcb64, 0xf9ff, 0xe876,
0x2102, 0x308b, 0x0210, 0x1399, 0x6726, 0x76af, 0x4434, 0x55bd,
0xad4a, 0xbcc3, 0x8e58, 0x9fd1, 0xeb6e, 0xfae7, 0xc87c, 0xd9f5,
0x3183, 0x200a, 0x1291, 0x0318, 0x77a7, 0x662e, 0x54b5, 0x453c,
0xbdcb, 0xac42, 0x9ed9, 0x8f50, 0xfbef, 0xea66, 0xd8fd, 0xc974,
0x4204, 0x538d, 0x6116, 0x709f, 0x0420, 0x15a9, 0x2732, 0x36bb,
0xce4c, 0xdfc5, 0xed5e, 0xfcd7, 0x8868, 0x99e1, 0xab7a, 0xbaf3,
0x5285, 0x430c, 0x7197, 0x601e, 0x14a1, 0x0528, 0x37b3, 0x263a,
0xdecd, 0xcf44, 0xfddf, 0xec56, 0x98e9, 0x8960, 0xbbfb, 0xaa72,
0x6306, 0x728f, 0x4014, 0x519d, 0x2522, 0x34ab, 0x0630, 0x17b9,
0xef4e, 0xfec7, 0xcc5c, 0xddd5, 0xa96a, 0xb8e3, 0x8a78, 0x9bf1,
0x7387, 0x620e, 0x5095, 0x411c, 0x35a3, 0x242a, 0x16b1, 0x0738,
0xffcf, 0xee46, 0xdcdd, 0xcd54, 0xb9eb, 0xa862, 0x9af9, 0x8b70,
0x8408, 0x9581, 0xa71a, 0xb693, 0xc22c, 0xd3a5, 0xe13e, 0xf0b7,
0x0840, 0x19c9, 0x2b52, 0x3adb, 0x4e64, 0x5fed, 0x6d76, 0x7cff,
0x9489, 0x8500, 0xb79b, 0xa612, 0xd2ad, 0xc324, 0xf1bf, 0xe036,
0x18c1, 0x0948, 0x3bd3, 0x2a5a, 0x5ee5, 0x4f6c, 0x7df7, 0x6c7e,
0xa50a, 0xb483, 0x8618, 0x9791, 0xe32e, 0xf2a7, 0xc03c, 0xd1b5,
0x2942, 0x38cb, 0x0a50, 0x1bd9, 0x6f66, 0x7eef, 0x4c74, 0x5dfd,
0xb58b, 0xa402, 0x9699, 0x8710, 0xf3af, 0xe226, 0xd0bd, 0xc134,
0x39c3, 0x284a, 0x1ad1, 0x0b58, 0x7fe7, 0x6e6e, 0x5cf5, 0x4d7c,
0xc60c, 0xd785, 0xe51e, 0xf497, 0x8028, 0x91a1, 0xa33a, 0xb2b3,
0x4a44, 0x5bcd, 0x6956, 0x78df, 0x0c60, 0x1de9, 0x2f72, 0x3efb,
0xd68d, 0xc704, 0xf59f, 0xe416, 0x90a9, 0x8120, 0xb3bb, 0xa232,
0x5ac5, 0x4b4c, 0x79d7, 0x685e, 0x1ce1, 0x0d68, 0x3ff3, 0x2e7a,
0xe70e, 0xf687, 0xc41c, 0xd595, 0xa12a, 0xb0a3, 0x8238, 0x93b1,
0x6b46, 0x7acf, 0x4854, 0x59dd, 0x2d62, 0x3ceb, 0x0e70, 0x1ff9,
0xf78f, 0xe606, 0xd49d, 0xc514, 0xb1ab, 0xa022, 0x92b9, 0x8330,
0x7bc7, 0x6a4e, 0x58d5, 0x495c, 0x3de3, 0x2c6a, 0x1ef1, 0x0f78
unsigned short docrc(unsigned short crci,unsigned char data)
unsigned short idx,crc;
crc=crci;
idx = (crc ^ data) & 0xff;
crc >>=8;
crc ^= crctbl[idx];
return crc;
int main(int argc, char ** argv)
int i,len=1;
unsigned char buffer[512];
unsigned char tmp;
unsigned short crc=0xffff;
buffer[0]=0xfe;
for (i=1;i<argc;i++)
tmp=strtol(argv[i],NULL,16);
crc=docrc(crc,tmp);
if((tmp==0xff) || (tmp==0xfe) || (tmp==0xfd))
buffer[len++]=0xfd;
tmp ^= 0x20;
buffer[len++]=tmp;
//printf("%04x\n",crc);
tmp=crc ^ 0xff;
buffer[len++]=0xfd;
tmp ^= 0x20;
buffer[len++]=tmp;
tmp=(crc>>8) ^ 0xff;
buffer[len++]=0xfd;
tmp ^= 0x20;
buffer[len++]=tmp;
buffer[len++]=0xff;
for(i=0;i<len;i++)
//printf("%02x ",buffer[i]);
printf("%c",buffer[i]);
//printf("\n");
crc=docrc(crc,crc ^ 0xff);
crc=docrc(crc,tmp);
return 0;
Equivalente Perlcode
#!/usr/bin/perl -w
use strict;
use Digest::CRC;
my $crc = Digest::CRC->new(
width => 16, init => 0xffff,
xorout => 0, refout => 1, poly => 0x1021, refin => 1, cont => 1
my $text = shift;
my $command = "\xcd\x01\x05\xff$text";
$crc->add($command);
my $checksum = "\xff\xff" ^ pack "v", $crc->digest;
$command .= $checksum;
$command =~ s/([\xfd-\xff])/"\xfd" . ($1 ^ "\x20")/ge;
my $packet = "\xfe$command\xff";
print $packet;
Protocol
bootloader (in EPROM)
starts program download if:
address == 0xFE ||
flash[5] !=0x23 || //programmed after rest of flash
flash[6] !=0xff //programmed to 0 by appication before
//reboot to request download
max 0x200 bytes/?message?
0xFD escape, next byte ^= 0x20
0xFE message start
0xFF message end
crc16_<<ccitt?>> over unescaped data,
including crc bytes should give 0xf0B8
message:
+0 ?
+1 0x05
+2 0x02 erase
" 0x05 program
" 0x0a done
+3 program: address low
+5 program: address high
+7 program: data (len = messagelen-7)
application (in FLASH)
0xFE message start
0xFF message end
message:
+1 0xFF bootload, writes 0x00 to flash[0x6], then reboots
+2 0x05 ? must be 0x05
+3 0x01 ? must be 0x01
+4 swver must be 0xffff or >= flash[0xE]
(=0x0504 = v4.5)
+6 hwver must be flash[0x14] (=0x03)
message:
+1 0x02 update bit_buf
+2 data (len=msg_size-1; max 0x400)
message:
+1 0xDB broadcast ?
+2 0x01 set telly? (note: no reset)
+3 idx bit to set ?
message:
+1 0xCD unicast ?
+2 0xFF to all ?
+3 0x02 bitbus set bytes +4 offs +6 data
" 0x05 set str by id +4 id +6 str
" 0x07 see 0x0c
" 0x0c cpy? 3E80 by id +4 id +6 data (words)
" 0x0d update str by id +4 id +6 str
+1 0xCD unicast ?
+2 addr must be my_addr (canot be 0xff)
+3 0x01 ? len==0x4 ? clr ? strobj.len=0
" 0x01 ? len!=0x4 ? clr ? +4 idx +5 pos +9 len
" 0x02 set stridx id +4 str_idx +5 id
" 0x04 set strobj flass +4 idx +5 val
" 0x05 set strobj str +4 idx +6 string
" 0x07 see 0x0c
" 0x09 cpy ? idx=myaddr? +4 data (words)
" 0x0a set displ_map_bright? +4 val
" 0x0b set telly bits? +4 idx +5 data (dwords)
" 0x0c ?cpy? +4 idx +5 data (words)
" 0x0d set substr substr +4 idx +5 data
" 0x0e set substr bitidxmap +4 str_idx +5 data (words)
" 0x0f set substr idxs +4 str_idx +5 data
