Reflow Oven
| Project Reflow Oven | |
| Contact | User:Crashjuh |
| Last Update | 2015-07-02 |
Because modern electronics components are tending more and more towards becoming SMD-only, and because the associated size reduction can also be very useful for space projects, we need a reflow oven.
Oven has been acquired. It is a cheap 1kW Everglades toaster oven and has been able to do very crude reflow.
A prototype for the controller has been built and successfully measures temperature. I (smeding) am currently hammering out the PID loop to keep it at a fixed temperature. After that, all it needs is a little bit of UI and we should be good to go.
We now have a real reflow oven and currently we are testing what the best settings are. Over time, these data are reported here.
Use by Revspace
The oven has 10 memory locations (Program number 01 till 10). At the moment we only have programmed program number 01. We program the programs for different PCB thicknesses.
| Program number | PCB Thickness | |
| 01 | 1.5 / 1.6 mm | |
| 02 | xx | |
| 03 | xx | |
| 04 | xx | |
| 05 | xx | |
| 06 | xx | |
| 07 | xx | |
| 08 | xx | |
| 09 | xx | |
| 10 | xx |
- Program number:
Enter : 01
- Preheat standby:
Enter : 080
- Preheat standby:
- Preheat airtemp:
Enter : 150
- Preheat airtemp:
- Preheat time:
Enter : 02:00
- Preheat time:
- Solder temp. :
Enter : 250
- Solder temp. :
- Solder time:
Enter : 01:30
- Solder time:
