Gebruiker:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
  • software-defined radio
Old project ideas:
  • do cool stuff with NRF24L01+ modules, e.g. connect one to the SPI bus of a Raspberry Pi
  • experiment with MQTT, a light-weight publish/subscribe framework for telemetry data
  • put the things above together in some kind of home automation project
  • build a colinear antenna out of RG-6 coaxial cable for the 70cm band (for receiving high-altitude balloons)
  • more radio stuff with the ham-it-up
  • implement dominoex/thor radio mode for a balloon payload, perhaps build a light-weight reusable library
  • come up with an algorithm to determine position/direction of bats as they pass a set of ultrasonic microphones, see StereoBatRecorder
    • I've tried direct correlation, works but sometimes gives errors on bat calls with little frequency sweep
    • Planning to try correlation of only the amplitude data (derived with a Hilbert transform)
New project ideas:
  • Use two old satellite dishes to allow speech to be transferred over some distance
    • Figure out focal point
    • Create some kind of dish mount
  • Reverse engineer the digital oscilloscope at revspace
    • Figure out screenshot image format
    • Try to find if there are other commands than the "send screenshot" command
  • More LedBanner audio visualisations
  • Create a RFM69HW TNC, based on code by flok
    • Remove 'flok' framing, make it comply with KISS protocol
    • Use 'infinite' package length mode to send typical TCP/IP frames (1500 bytes)
  • Create a 'HabAlert' android app
    • Goal: get a notification on your smartphone when a highaltitude ballon (HAB) is coming into reception-range
    • How:
      • use a dedicated machine to retrieve current HAB positions from spacenear.us or habhub.org
      • keep track of HabAlert subscriptions, check notification conditions and send out notifications
      • use (for example) google cloud messaging framework to send push notifications that are quick and low-power
      • android client application receives notification, shows current HABs in either list (sorted by 'visibility') or map
  • add opus audio codec support to squeezeboxserver and/or squeezelite
