GL-iNet
Versie door Juerd (overleg | bijdragen) op 23 aug 2014 om 00:15
Project GL-Inet
Contact User:FooBar
Last Update 2014-08-23
GL-Inet
GL-Inet
GL-Inet
GL-Inet
GL-Inet vs TP WR-703
GL-Inet board
GL-Inet.com creates nice clones of TP-Link WR-703 routers. They run OpenWRT out of the box, and have 2 ethernet interfaces, a 2.4Ghz Wifi (802.11n) radio, a usb2.0 port and 5 free GPIO ports. Available on dealextreme/alibaba or in the RevSpace vending machine.
RevSpace images and packages
Alternative packages and install-images for OpenWrt (trunk) for GL-Connect GL-iNet v1 (GL-iNet-6416A) devices, Build-environment for the GL-Inet, http://glinet.sigio.nl/. You will need the openwrt-ar71xx-generic-gl-inet-v1-squashfs-factory.bin file, md5sum ad2164a70e4ccc9a40f77bf49d3bb472
Note that using a custom build means you can't use the normal repositories for kernel-packages.
Specifications
Model GL-iNet 6408A / 6416A
CPU Atheros AR9330 rev 1 - MIPS 24Kc V7.4 (265.42 BogoMIPS) 400Mhz
Ram DDR 64MB
Rom 8MB (6408A), 16M (6416A)
Interface 2× 100mbit/s RJ-45 (LAN/WAN), 1× USB2.0, 1× Micro USB (power)
LED Red and green. When both turned on amber-ish.
Wireless IEEE802.11n/g/b、IEEE802.3、IEEE802.3u
Button Press to toggle wireless radio; Press and hold for 8 seconds to restore factory default settings
Antenna Inverted F PCB trace antenna DN007 *1 https://www.ti.com/lit/an/swru120b/swru120b.pdf http://hackaday.com/2014/02/28/pcb-antenna-reference-designs/
Browser Support Chrome/Safari/Firefox/IE8-IE10
Mobile app Android, iOS (links plz!)
Dynamic DNS Free build-in dynamic DNS
USB Storage Support Support FAT32/EXFAT/EXT4/ETX3/EXT2/NTFS. FAT32/NTFS suggested.
USB Webcam Support MJPG or YUV
Firmware upgrade One-click upgrade; auto upgrade.
DIY Features Uboot web interface; Uart soldered; 5 GPIO
Power Supply 5V/1A micro USB (not included @ RevSpace market)
Size 58mm*58mm*22mm
Weight 42g (router only)
Power Consumption Less than 1 watt
Temperature Working temperature 0°C - 45°C. Storage Temperature -40°C - 70°C
OpenWRT
GL-Inet Pinout
The device runs OpenWRT out of the box, but it's quite easy to build your own image.
Serial settings
  • Baudrate: 115200
  • Handshake: none
  • Flow-control: none
Hacks
External antenna
Maxell's shopping list for the external antenna modification.
  • IPX naar RP-SMA pigtail, RG178: [1]
  • Surface mount IPX: [2]
Display =
Widely sold as the "Nokia5110 display" (but actually most famous for being the display of the Nokia 3310), this 84 × 48 graphical display can easily be added to a GL-Inet and controlled by bitbanging SPI with the GPIO pins. It uses 4 GPIOs, leaving one vacant, if you simply tie CE/SCE to GND.
OpenWRT Patch: https://dev.openwrt.org/ticket/15632
Build instructions for OpenWRT: https://gitlab.com/Raymii/openwrt-gl-inet/tree/master
OpenWRT Forum topic: https://forum.openwrt.org/viewtopic.php?id=47715&p=2
Images: http://galeria.tech-blog.pl/GLiNet/
More images: http://shiki.tk/?p=2888
External antenna: http://shiki.tk/?p=2940
LAG Project page: https://wiki.laglab.org/Gl.inet
