GL-iNet
| Project GL-Inet | |
| Contact | User:FooBar |
| Last Update | 2014-06-09 |
GL-Inet.com creates nice clones of TP-Link WR-703 routers. They run OpenWRT out of the box, and have 2 ethernet interfaces, a 2.4Ghz Wifi (802.11n) radio, a usb2.0 port and 5 free GPIO ports. Available on dealextreme/alibaba or in the RevSpace vending machine.
RevSpace images and packages
Alternative packages and install-images for OpenWrt (trunk) for GL-Connect GL-iNet v1 (GL-iNet-6416A) devices, Build-environment for the GL-Inet, http://glinet.sigio.nl/. You will need the openwrt-ar71xx-generic-gl-inet-v1-squashfs-factory.bin file, md5sum ad2164a70e4ccc9a40f77bf49d3bb472
Note that using a custom build means you can't use the normal repositories for kernel-packages.
Specifications
| Model | GL-iNet 6408A / 6416A |
| CPU | Atheros AR9330 rev 1 - MIPS 24Kc V7.4 (265.42 BogoMIPS) 400Mhz |
| Ram | DDR 64MB |
| Rom | 8MB (6408A), 16M (6416A) |
| Interface | 2× 100mbit/s RJ-45 (LAN/WAN), 1× USB2.0, 1× Micro USB (power) |
| LED | Wirless, Power |
| Wireless | IEEE802.11n/g/b、IEEE802.3、IEEE802.3u |
| Button | Press to toggle wireless radio; Press and hold for 8 seconds to restore factory default settings |
| Antenna | PCB trace antenna DN007 *1 https://www.ti.com/lit/an/swru120b/swru120b.pdf http://hackaday.com/2014/02/28/pcb-antenna-reference-designs/ |
| Browser Support | Chrome/Safari/Firefox/IE8-IE10 |
| Mobile app | Android, Ios |
| Dynamic DNS | Free build-in dynamic DNS |
| USB Storage Support | Support FAT32/EXFAT/EXT4/ETX3/EXT2/NTFS. FAT32/NTFS suggested. |
| USB Webcam Support | MJPG or YUV |
| Firmware upgrade | One-click upgrade; auto upgrade. |
| DIY Features | Uboot web interface; Uart soldered; 5 GPIO |
| Power Supply | 5V/1A micro USB (not included @ RevSpace market) |
| Size | 58mm*58mm*22mm |
| Weight | 42g (router only) |
| Power Consumption | Less than 1 watt |
| Temperature | Working temperature 0°C - 45°C. Storage Temperature -40°C - 70°C |
OpenWRT
The device runs OpenWRT out of the box, but it's quite easy to build your own image. Currently revspace has 1 GL-inet 16MB device, and an order has been made for a batch of 20, which should arrive somewhere around the end of April 2014.
Serial settings
- Baudrate: 115200
- Handshake: none
- Flow-control: none
OpenWRT Patch: https://dev.openwrt.org/ticket/15632
Build instructions for OpenWRT: https://gitlab.com/Raymii/openwrt-gl-inet/tree/master
OpenWRT Forum topic: https://forum.openwrt.org/viewtopic.php?id=47715&p=2
Images: http://galeria.tech-blog.pl/GLiNet/
More images: http://shiki.tk/?p=2888
Externe antenne: http://shiki.tk/?p=2940
LAG Project page: https://wiki.laglab.org/Gl.inet
