3d-printer-compare
Versie door Semafoor (overleg | bijdragen) op 14 mei 2014 om 13:23 (corrected the *footnote)
3D printer vergelijking
Besproken op de metameet van 13x05x2014. Eerste model (Mankati) is via Rix, tweede model (Carteso) zit in maasstricht en Lulzbot onbekend.
Mankati Fullscale XT Cartesio W1CE Lulzbot TAZ 4 Ultimaker II
Price 2150 3600 2195 € 2300 incl. BTW
PLA YES x YES YES
ABS YES x YES YES
PVA YES x YES ?
Filament Diameter 3 mm 3 mm 3 mm 2.85 mm
Filament Temp 150 tot 250 °C x max 240 °C 180 - 260 °C
File support stl, obj, gcode x STL / OBJ / DAE / AMF
Print speed -180 mm/s -150 mm/s -200 mm/s 30-300 mm/s
Accuracy* X,Y axis 0.0125 mm, Z axis 0.001 mm 0,28 mm 0,1 mm 0.0125 mm (X,Y), 0.005 mm (Z)
Stepper Motor* X, Y 4248, 1.3A, Z 4263, 1.5A x x x
Controller* Arduino Mega 2560 R3 x open source YES
Linux YES x YES YES
Software MankatiUM (Based on Cura) x x Cura
Extruders max 2 max 4 max 1
Max. print dimensions 250×250×300 mm 400x200x200 mm 297x274x248 mm 230x225x205 mm
Extrude Nozzle 0,4 mm (0,3 en 0,5 beschikbaar) x 0.075mm to 0.35mm 0.4 mm
Hot bed YES x YES 50-100 °C
Bed materiaal Monocrystal glass x Borosilicate glass bed covered with PET film glass
Closed printing area Ja Ja Nee closed sides, open front/top
External dimensions 380x420x530 mm x 680x520x515 mm 492x342x558 mm (incl. filament)
Weight* 25kg x 11kg YES
Notes x Graveert ook Open source hardware & software, print ook nylon, Laywood, Laybrick & Ninjaflex
Link http://www.mankati.com/fullscale-xt.html http://mauk.cc/webshop/systems/cartesio-assembled/Cartesio-w1ce-assembled https://www.lulzbot.com/products/lulzbot-taz-4-3d-printer https://www.ultimaker.com/pages/our-printers/ultimaker-2
x = niet bekend
* = unreliable or irrelevant specification
