ImprovedLaosLaser
Revision as of 15:09, 8 January 2014 by Maxell (talk | contribs)
Project Improved LaosLAser
Contact FooBar
Last Update 2014-01-08
Thanks to Stoneshop @ #42 there is an improved LaosLaser board design available:
Schematic
Board
BOM
Part Value Device Package Description
C1 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C2 100u 25V CPOL-EUE5-8.5 E5-8,5 POLARIZED CAPACITOR
C3 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C4 1000u 25V CPOL-EUE5-13 E5-13 POLARIZED CAPACITOR
C5 100n C-EU050-025X075 C050-025X075 CAPACITOR
C6 100u 25V CPOL-EUE5-10.5 E5-10,5 POLARIZED CAPACITOR
C7 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C8 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C9 100u 25V CPOL-EUE5-8.5 E5-8,5 POLARIZED CAPACITOR
C10 100u 25V CPOL-EUE5-8.5 E5-8,5 POLARIZED CAPACITOR
C11 100u 25V CPOL-EUE5-8.5 E5-8,5 POLARIZED CAPACITOR
C12 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C13 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C14 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C15 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C16 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C17 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C18 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C19 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C20 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
C21 100u 10V CPOL-EUE5-8.5 E5-8,5 POLARIZED CAPACITOR
C22 100n C-EU025_050-025X075 C025_050-025X075 CAPACITOR
IC1 PCA82C250 PCA82C250 DIL08 CAN CONTROLLER INTERFACE
J4 SI-50170 SI-50170 SI-50170 Ethernet Connector MagJack (R)
J6 SJ SJ SMD solder JUMPER
J7 JP3Q JP3Q JUMPER
J12 SJ SJ SMD solder JUMPER
J13A SJ SJ SMD solder JUMPER
J13B SJ SJ SMD solder JUMPER
J13C SJ SJ SMD solder JUMPER
J15 SJ SJ SMD solder JUMPER
J16 JP3Q JP3Q JUMPER
J19 SJ SJ SMD solder JUMPER
J20A SJ SJ SMD solder JUMPER
J20B SJ SJ SMD solder JUMPER
J20C SJ SJ SMD solder JUMPER
J21 SJ SJ SMD solder JUMPER
J22 JP3Q JP3Q JUMPER
J25 SJ SJ SMD solder JUMPER
J26A SJ SJ SMD solder JUMPER
J26B SJ SJ SMD solder JUMPER
J26C SJ SJ SMD solder JUMPER
J27 GMSTBA4 GMSTBA4 GMSTBA4 PHOENIX
J28 JP2E JP2 JUMPER
J30 SJ SJ SMD solder JUMPER
J31 JP3Q JP3Q JUMPER
J35 SJ SJ SMD solder JUMPER
J36A SJ SJ SMD solder JUMPER
J36B SJ SJ SMD solder JUMPER
J36C SJ SJ SMD solder JUMPER
J40 SJW SJW SMD solder JUMPER
J41 JP2E JP2 JUMPER
J42 JP2E JP2 JUMPER
JP2 PINHD-1X04_2.54 1X04 PIN HEADER
JP10 PINHD-1X04_2.54 1X04 PIN HEADER
JP14 PINHD-1X04_2.54 1X04 PIN HEADER
JP29 PINHD-1X04_2.54 1X04 PIN HEADER
JP34 PINHD-1X04_2.54 1X04 PIN HEADER
JP37 PINHD-1X04_2.54 1X04 PIN HEADER
JP39 PINHD-1X04_2.54 1X04 PIN HEADER
KIT1 MBED_NXP_LPC1768 MBED_NXP_LPC1768 MBED-KIT Mbed LPC1768 - ARM CORTEX v2.1
LED1 LED3MM LED3MM LED
LED2 LED3MM LED3MM LED
LED3 LED3MM LED3MM LED
MOT_FEED GMSTBA5 GMSTBA5 GMSTBA5 PHOENIX
OK1 ILQ620 ILQ620 DIL16 SIEMENS OPTO COUPLER
OK2 ILQ620 ILQ620 DIL16 SIEMENS OPTO COUPLER
POWER GMSTBA4 GMSTBA4 GMSTBA4 PHOENIX
R1 120R R-EU0207/2V 0207/2V RESISTOR
R2 330R R-EU0207/10 0207/10 RESISTOR
R3 330R R-EU0207/10 0207/10 RESISTOR
R4 1k R-EU0207/10 0207/10 RESISTOR
R5 2k2 R-EU0207/10 0207/10 RESISTOR
R6 1k R-EU0207/10 0207/10 RESISTOR
R7 2k2 R-EU0207/10 0207/10 RESISTOR
R8 2k2 R-EU0207/10 0207/10 RESISTOR
R9 10k R-EU0207/10 0207/10 RESISTOR
R10 10k R-EU0207/10 0207/10 RESISTOR
R11 1k R-EU0207/10 0207/10 RESISTOR
R12 1k R-EU0207/10 0207/10 RESISTOR
R13 10k R-EU0207/10 0207/10 RESISTOR
R14 1k R-EU0207/10 0207/10 RESISTOR
R15 1k R-EU0207/10 0207/10 RESISTOR
R16 10k R-EU0207/10 0207/10 RESISTOR
R17 1k R-EU0207/10 0207/10 RESISTOR
R18 10k R-EU0207/10 0207/10 RESISTOR
R19 10k R-EU0207/10 0207/10 RESISTOR
R20 1k R-EU0207/10 0207/10 RESISTOR
R21 10k R-EU0207/10 0207/10 RESISTOR
R22 10k R-EU0207/10 0207/10 RESISTOR
R23 1k R-EU0207/10 0207/10 RESISTOR
R24 1k R-EU0207/10 0207/10 RESISTOR
R25 10k R-EU0207/10 0207/10 RESISTOR
R26 1k R-EU0207/10 0207/10 RESISTOR
R27 1k R-EU0207/10 0207/10 RESISTOR
R28 330R R-EU0207/10 0207/10 RESISTOR
R29 330R R-EU0207/10 0207/10 RESISTOR
R30 1k R-EU0207/10 0207/10 RESISTOR
R31 330R R-EU0207/10 0207/10 RESISTOR
R32 330R R-EU0207/10 0207/10 RESISTOR
R33 100 R-EU0207/10 0207/10 RESISTOR
R34 100 R-EU0207/10 0207/10 RESISTOR
T1 BD647V BD647V TO220AV NPN BIPOLAR DARLINGTON TRANSISTOR
T2 BD647V BD647V TO220AV NPN BIPOLAR DARLINGTON TRANSISTOR
U$1 POLOLU_A4983CARRIER POLOLU_A4983CARRIER A4988BREAKOUT
U$2 POLOLU_A4983CARRIER POLOLU_A4983CARRIER A4988BREAKOUT
U$3 POLOLU_A4983CARRIER POLOLU_A4983CARRIER A4988BREAKOUT
U$5 R-78B*-* R-78B*-* R-78B**-* RECOM R-78B**-* switching regulator (78xx compatible)
U$6 POLOLU_A4983CARRIER POLOLU_A4983CARRIER A4988BREAKOUT
U4 SD_CARD_SOCKETSD SD_CARD_SOCKETSD SD-MMC_SOCKET-PP SD/MMC Socket
U11 SD_CARD_SOCKETSD SD_CARD_SOCKETSD SD-MMC_SOCKET-PP SD/MMC Socket
X1 PN87520-S PN87520-S PN87520-S BERG USB A connector (shielded)
X2 B5B-XHB B5B-XHB B5B-XH XH CONNECTOR 2.5 mm, 5 pin 1 row
X3 B5B-XHB B5B-XHB B5B-XH XH CONNECTOR 2.5 mm, 5 pin 1 row
X4 B5B-XHB B5B-XHB B5B-XH XH CONNECTOR 2.5 mm, 5 pin 1 row
X5 B5B-XHB B5B-XHB B5B-XH XH CONNECTOR 2.5 mm, 5 pin 1 row
X6 B4B-XHB B4B-XHB B4B-XH XH CONNECTOR 2.5 mm, 4 pin 1 row
X7 B4B-XHB B4B-XHB B4B-XH XH CONNECTOR 2.5 mm, 4 pin 1 row
X8 B4B-XHB B4B-XHB B4B-XH XH CONNECTOR 2.5 mm, 4 pin 1 row
X9 B4B-XHB B4B-XHB B4B-XH XH CONNECTOR 2.5 mm, 4 pin 1 row
X10 B4B-XHB B4B-XHB B4B-XH XH CONNECTOR 2.5 mm, 4 pin 1 row
X11 B4B-XHB B4B-XHB B4B-XH XH CONNECTOR 2.5 mm, 4 pin 1 row
X12 B4B-XHB B4B-XHB B4B-XH XH CONNECTOR 2.5 mm, 4 pin 1 row
X13 B4B-XHB B4B-XHB B4B-XH XH CONNECTOR 2.5 mm, 4 pin 1 row
XMOT GMSTBA5 GMSTBA5 GMSTBA5 PHOENIX
YMOT GMSTBA5 GMSTBA5 GMSTBA5 PHOENIX
ZMOT GMSTBA5 GMSTBA5 GMSTBA5 PHOENIX
