PowerLight
Revision as of 12:01, 3 December 2024 by Bertrik Sikken (talk | contribs) (Nederlands energie dashboard API)
Project PowerLight
Shows mix of dutch electrical power generation as a pie chart on a LED ring
Last Update 2024-12-03
1. The concept
Show the current dutch electrical power generation-mix as pie chart on a LED ring light, with colors representing fractions of a specific power generation source.
For example:
  • yellow: solar
  • blue: wind
  • red: fossil
  • green: nuclear
  • purple: other/waste
2. Power generation data
2.1. ENTSO-E data
  • B01 (biomass): always 0, not useful
  • B02: not available
  • B03: not available
  • B04 (fossil hard coal): useful
  • B05 (fossil gas): useful
  • B06: not available
  • B07: not available
  • B08: not available
  • B09 (geothermal): not available
  • B10 (hydro): not available
  • B11 (hydro): always 0
  • B12 (hydro): not available
  • B13 (marine): not available
  • B14 (nuclear): useful
  • B15 (other renewable): not available
  • B16 (solar): hugely underreported, *not* useful
  • B17 (waste): useful
  • B18 (wind offshore): useful
  • B19 (wind onshore): useful
  • B20 (other): useful
  • B16 (solar)
2.1.1. Data schedule
2.2. The model I use for the energy generation mix of the Netherlands
Main points relevant for me:
In my backend application, energy generation fractions are calculated as follows:
  • solar = B16 (from the time-shifted forecast document A69)
  • wind = B18 (offshore, from generation document A75) + B19 (onshore, from time-shifted forecast document A69)
  • fossil = B04 (gas) + B05 (coal)
  • nuclear = B14
  • waste = B17
  • other = B20
In the end, all of the electrical generation data used in my backend application is ENTSO-E data.
2.3. Data model behind CO2monitor.nl
Analysis:
  • Much of the data comes from ENTSO-E, except for at least solar, wind, biomass, WKK
  • Biomass data seems to follow the coal data exactly in shape. The sum of the biomass and coal numbers at CO2monitor equal exactly the ENTSO-E hard coal number.
  • CO2monitor must be assigning some fraction of the ENTSO-E hard-coal number to biomass, it is unknown how they arrive at this fraction
  • The biomass fraction seems to be 1295/2740 = 47.3% (data from 18 november 2023)
Some data from CBS on energy use for electricity production in 2022: https://opendata.cbs.nl/statline/#/CBS/nl/dataset/80030NED/table?fromstatweb
  • total energy from coal: 53315 TJ
  • total energy from biomass: 34798 TJ
This means a ratio of 39.5% biomass vs (biomass + coal), not exactly the CO2monitor number, but on the same order
2.4. Nederlands energie dashboard API
Notes:
  • Het content-type is standaard application/json+ld, je ontvangt dan JSON met 'linked data', data is dan gewrapped in een andere structuur. Content-type application/json werkt ook.
  • De argumenten zijn case-sensitive, argumenten moeten met kleine letter beginnen. De documentatie toont hoofdletters.
  • De volgorde van argumenten is belangrijk, een verkeerde volgorde leidt tot time-outs. Voor de 'juiste' volgorde kan je best de voorbeelden volgen. In ieder geval 'point' of 'validfrom' eerst.
  • Het 'utilization' endpoint levert altijd tijdreeksen op. De fijnste resolutie van begin/eind een tijdreeks is een dag. De API heeft geen specifieke mogelijkheid voor opvragen van de meest recente / actuele waarde, je kan de gegevens voor de hele dag opvragen en dan de meest recente waarde gebruiken. Voor verschillende bronnen moet je losse calls maken (let op: rate limit).
Mapping van ned.nl data naar energie-ring:
  • solar = 2 (solar)
  • wind = 1 (wind) + 51 (offshoreC)
  • fossil = 18 (FossilGasPower) + 19 (FossilHardCoal) = zelfde data als ENTSO-E (minus de aanname over de biomassa-fractie?)
  • nuclear = 20 (Nuclear) = zelfde data als ENTSO-E?
  • waste = 21 (WastePower) = zelfde data als ENTSO-E?
  • other = 26 (OtherPower)
Wat nog onduidelijk is:
  • Timestamp van data lijkt 'te nieuw', veel van de data komt van entso-e, die loopt al 30-46 minuten achter.
  • Bronnen lijken overlap te hebben, hoe voorkom je dat je dingen dubbel telt?
    • Bijvoorbeeld biomass, bio-oil, bio-methane, "biomasspower", wood en cofiring, gaat allemaal over biomassa.
  • Onderscheid verwarming / elektriciteitsopwek
    • Other vs OtherPower, is de eerste inclusief warmte, en de tweede waarschijnlijk alleen elektriciteit
  • Er zijn verschillende modellen voor offshore-wind, maar juist de onshore-wind heeft veel onzekerheid
  • Hoe werkt het zonne-opwekmodel?
  • Bron 'All' is *alleen* hernieuwbare fractie?
  • Gerapporteerde wind-opwek vertoont grote fluctuaties, heeft te maken met de update intervallen
  • Opwek omgerekend naar instantaan vermogen (of KWh / uur) wordt 'capacity' genoemd, merkwaardige naamgeving.
3. Hardware
Parts:
Connecting it:
  • Solder the straight pin headers that came with it on the wemos d1 mini
  • Solder the angled pin to the LED ring
  • Connect the dupont cable:
    • Wemos 5V goes to 5V on the LED ring
    • Wemos GND goes to GND on the LED ring
    • Wemos D3 goes to DI on the LED ring
    • Wemos D2 goes to DO on the LED ring
Diffuser: https://www.thingiverse.com/thing:751894 resize to 89x89x8 mm
4. Software
  • The backend part that collects the power generation data, written in Java, running on a VPS
  • The light part that visualizes the power generation as fractions on a LED ring, running on an Arduino
4.1. Backend
Runs as a REST-like resource, with the following endpoints:
Returns JSON-structures like:
  "time": 1700728200,
  "datetime": "2023-11-23T09:30:00+01:00",
  "total": 13552,
  "mix": [
    { "id": "solar", "power": 1232, "color": "#FFFF00"},
    { "id": "wind onshore", "power": 4241, "color": "#0000FF"  },
    { "id": "wind offshore", "power": 2963, "color": "#0000FF"  },
    { "id": "fossil gas", "power": 2264, "color": "#FF0000"  },
    { "id": "fossil coal", "power": 2051, "color": "#FF0000"  },
    { "id": "nuclear", "power": 483, "color": "#00FF00"  },
    { "id": "waste", "power": 70, "color": "#FF00FF"  },
    { "id": "other", "power": 248, "color": "#FF00FF"  }
  • time is a unix time stamp in seconds, representing the end of the 15-minute period that the power figures refer to
  • dateime is ta user-readable time stamp, in dutch local time + offset
  • total is the total most recent electrical power (megawatt), suitable for display (on a numeric display inside the ring for example)
  • mix is an array of power sources, each with:
    • a short unique id
    • most recent known power (megawatt)
    • hex color, for display on the led ring
  "current": { "date": "2022-10-30","price": 32.02 },
  "day-ahead": [
    { "date": "2022-10-31", "price": 62.631 },
    { "date": "2022-11-01", "price": 49.293 }
4.2. Display
4.2.1. LED ring energy mix
Hardware that I used:
  • Wemos D1 mini, contains an ESP8266 + USB-serial converter
  • 24-led pixel ring, for example this one https://nl.aliexpress.com/item/32963152993.html
  • "dupont"-cable, you need 4 wires
    • wemos 5V to LED ring 5V
    • wemos GND to LED ring GND
    • wemos D3 to LED ring DI
    • wemos D2 to LED ring DO
Firmware installation:
  • compiled using platformio
  • clone the code from github, enter the PowerLight directory
  • pio run -t upload
Configuration:
  • connect over WiFi to the "ESP-POWERLIGHT" network (no password)
  • open page at 192.168.4.1
  • enter WiFi credentials (select a network + password)
4.2.2. LED ring price clock
  • LED ring with 24 coloured leds, 2 leds per hour
  • colour indicates relative price, green = low, red = high
  • indicate current time by making the corresponding LED extra bright
Interesting links:
4.2.3. ElectricityPrice
4.2.3.1. T-Display
4.2.3.2. SHA-badge
Micropython:
  • ++ possibly quick development, script can be shared with other people
  • ++ has working libs for fetching HTTP, decoding JSON, controlling the display
  • -- script needs frequent garbage collection to avoid crashing?
  • -- unclear how to get a python script on this thing
  • -- sha badge firmware bootloops, currently unusable to me
Arduino:
  • ++ I know this environment, don't have to debug existing bootlooping firmware, no compiler setup required
  • ++ Already have HTTP and JSON working on Arduino
  • ++ Code starts immediately, no user interaction required
  • -- not sure if there is a usable epaper driver
