Karaburan
Project Karaburan
Monitoring water quality
Status Initializing
Last Update 2024-04-29
Topics:
  • air quality sensors
    • ammonia
    • NOx
  • water chemical analysis
    • nitrates
    • ammonia
    • dissolved oxygen
    • sulfide/sulfate
    • phosphates?
    • salinity (chlorides?)
  • water physical analysis
    • temperature
    • depth?
  • boat control
    • trajectory -> steering
  • camera control
  • post-processing
    • data presentation
      • video/photo stitching
      • time lapse view
      • map view of properties
  • use cases
    • minimum viable prototype
  • materials
    • boat selection
Air quality sensors
Nitrogen compounds in air
  • NOx: 27.3 ug/m3
  • NO2: 18.6 ug/m3 (9.9 ppb)
Water physical analysis
Turbidity / clarity
So the Aliexpress sensor is mostly suited for very dirty water.
Boat control
  • 2.4 GHz working frequency
  • 500m range
Interesting links:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
  • slootview, inspect water sides over time
